Never Satisfied
- Oct 10, 2017
- Madison
Fuel pressure goes up with boost so it's getting more fuel unless the injectors are maxed out which they may be close to at 18 psi.
Turboflash
- Mar 18, 2019
- Southern MN
Stock fuel pump and stock injectors are "all in" at 18 psi boost at temps like -10 degF.
twyztid
- Feb 14, 2011
- Middleville, MI
- 2025 Sidewinder LTX LE EPS
2017 Sidewinder LTX SE
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
It appears that there is no control of the wastegate. The wastegate closes when the wastegate solenoid bleeds off pressure in the line. If you were to remove the tube that goes from the solenoid to the wastegate and plug it, you would get very low boost because the wastegate would just blow open. He has tested the actuation of the wastegate arm on turbo that is installed and the turbo that he removed from it last spring. Both start to open at about 8psi and are fully open at about 20psi (using a MityVac pump). The tubes were all checked as well and there are not leaks.
The wastegate solenoid is normally closed. That means that if the solenoid wasn't getting a signal from the ECU (from something like a rubbed through wire or something), the wastegate would be free too open and it wouldn't build much boost. That is not the case here. He has also pressurized the wastegate solenoid directly and it didn't leak (sled off).
Has anyone ever experienced a bad tune that just wasn't controlling the wastegate properly? It's almost as if the wastegate solenoid is getting a signal to stay wide open. Sebastian at PEFI is saying that with no wastegate control, the boost will be around the 18.5 range (+ or - a little). He is also still saying that it is not possible that it is the tune. We're at a loss here for more ideas of what is causing the overboosting and/or lack of wastegate control.
Mike Bennett
- Jan 6, 2021
- Des Moines
- 2020 Tcat
I too had my Speedwerx PEFI stage 3 go down. all symptoms point to head gasket but dealer did leak down and it checked normal. It is injecting coolant into the oil. He will be tearing head off in next day or so and asked me to ask Speedwerx if they would examine the ECU for a corrupt file. I called them and was told they are almost 100% sure the center piston went lean from lack of fuel. They told me they have done 800 of these and only three have gone down and that was due to a customer holding it Wide open and then letting off and getting back in it, while they had a half tank of gas, and fuel pump could not keep up. I told them I had a full tank of gas and mine went down in the first three miles after installing the tune. I was told that I must get the hi flow fuel pump. Nowhere on Speedwerx or PEFI site does it say that a sage 3 needs that. If that is true why didn't they tell me that when they sold me the tune? They tried to sell me clutching as well as an cold air intake and intercooler tunes. Needless to say I am pissed as hell. Can you recall max boost on the gauge flash? Is there an independent place that could verify the flash is not corrupt as they aren't very "helpful". Can dealer scan ECU to read max boost without erasing flash?
twyztid
- Feb 14, 2011
- Middleville, MI
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
I don't have an answer to your questions but I am curious as well.
justinator
- Mar 25, 2007
- Maine
- 2023 Arctic Cat Riot 9000
Shouldnt need the big pump for stage 3. the stage 3r on the other hand has a big pump and 3 bar sensor as indicated on precisions site. If running hard off and on the throttle with low fuel was an issue then youd hear about alot of other 280,290 and 300 hp sleds going down from the other tuners as well. My sled has never indicated a lean condition on hrs of datalogging on different days and different conditions and many times with slim levels of fuel in the tank. Hope you guys get some more solid answers soon.I too had my Speedwerx PEFI stage 3 go down. all symptoms point to head gasket but dealer did leak down and it checked normal. It is injecting coolant into the oil. He will be tearing head off in next day or so and asked me to ask Speedwerx if they would examine the ECU for a corrupt file. I called them and was told they are almost 100% sure the center piston went lean from lack of fuel. They told me they have done 800 of these and only three have gone down and that was due to a customer holding it Wide open and then letting off and getting back in it, while they had a half tank of gas, and fuel pump could not keep up. I told them I had a full tank of gas and mine went down in the first three miles after installing the tune. I was told that I must get the hi flow fuel pump. Nowhere on Speedwerx or PEFI site does it say that a sage 3 needs that. If that is true why didn't they tell me that when they sold me the tune? They tried to sell me clutching as well as an cold air intake and intercooler tunes. Needless to say I am pissed as hell. Can you recall max boost on the gauge flash? Is there an independent place that could verify the flash is not corrupt as they aren't very "helpful". Can dealer scan ECU to read max boost without erasing flash?
twyztid
- Feb 14, 2011
- Middleville, MI
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
Update...
He has now tried all of the following parts that he has swapped from other sleds that are running correctly but his is still overboosting. He has also checked his boost gauge again and is DOES read correctly.
Wastegate solenoid
BOV solenoid
MAP sensor
2.5" TD trail muffler (not sure if the real name)
ECU w/ TD Max Spool 17 tune
Stock BOV
New turbo (previously)
When he had the stock BOV installed, he also installed a stock ECU & stock muffler and saw around 11.5-11.8 psi so he is even overboosting with a completely stock setup. Very frustrating because there isn't really anything left to try.
Wastegate solenoid
BOV solenoid
MAP sensor
Stock BOV
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
Update...
Wastegate solenoid
BOV solenoid
MAP sensor
Stock BOV
11.5-11.8 is normal for a stock sled.
twyztid
- Feb 14, 2011
- Middleville, MI
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
Sebastian at PEFI told him that it shouldn't be above 10psi... so who is correct?
twyztid
- Feb 14, 2011
- Middleville, MI
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
He has his boost gauge tee'd into the line that runs to the MAP sensor, wastegate solenoid, and BOV solenoid. It is in the line about 6" above those items. I don't know these sleds well enough to know if that is the line that is referred to in the post that you gave me.
Crossfire12
- Feb 13, 2017
- New York Adirondacks
- 2010 Z1 Turbo ,2017 zr9000, F1100 turbo, 700 srx
- Sacandaga reservoir
I’d second knapps findings, a little elevation changes mine higher, but all ok
KnappAttack
- Feb 19, 2004
- Welch MN
Depends on altitude and barometric pressure. Up in altitude, up in pressure. The ECU compensates to the barometric pressure.
DC5
Maybe it’s a problem with the barometric pressure sensor? If it was reading low it may up the boost to compensate
twyztid
- Feb 14, 2011
- Middleville, MI
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
We're at about 800' above sea level here.Depends on altitude and barometric pressure. Up in altitude, up in pressure. The ECU compensates to the barometric pressure.
