Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
Was the 0W40 more expensive? Maybe its a marketing plan
Yes a bit more for the Full syn but I get a 10-15% discount on all in store items! Makes it a bit more feasible!
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Oil threads my favorite!
Turboflash
- Mar 18, 2019
- Southern MN
Yup, never-ending round and round.
I figure I'm riding a $25,000 sled. If I have to spend $75 once a year for the best oil, it just doesn't matter at all.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Yep, like someone's trolling.
yamahaguy
Ride SAFE
- Apr 20, 2014
- 2015 Yamaha MTX LE with MPI
You can tell the snow is gone when the great oil debate thread starts again! Haha
Most every Viper in the off Trail group I ride with run 5w30 Mobil 1 full synthetic. Turbos and NA both.
Thats my 2 cents.
Thats my 2 cents.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- 2015 Viper 270 hurricane,
- Wisconsin
Google itSo your telling me yamaha gives us 20 years of warranty with the oil they recomend but its no good it cokes there bearings,explain
lilrez
Correct 0w40 synthetic for cats version of the 998 engine.Did I read somewhere here that Yamaha recommended oil is 0W-30? Cat recommended oil is 0W-40.
Mototown
yes they changed there recommendations to the o-40 syn on the motorI have always used what the dealer that I purchased my sled from recommended.
They recommended the 0-30 semi syn for the first 2 seasons, then changed their recommendation to the 0-40 full syn this past season. Not sure why? but I will say that I have not had to add any during the season. Does not use any oil and that is great. I would not have noticed the difference powerwise whereas I updated my tune from a 2 bar to the newer 3bar, both Max Spool 16. Had I done nothing more then changing oil types, it may have shown. Sounds like I should try a o-30 full syn next year? Plenty of time to think about that between now and next season.
lilrez
stevewithOCD
Yamaha, Make me Come Back
- Jan 1, 2008
- Live CT Ride MAINE
- 900 R
2006 Apex RTX
People can put whatever oil they want in their sled, but no way no how would I use a 40 weight oil in the Sidewinder if you want all its performance. Apparently you missed the gripe of a performance loss by one of the Magazines where they lost speed after an oil change, I'm certain the dealer put in a 40 wt. oil in place of the 30 wt oil. I have experienced firsthand a loss of power running 40 wt. vs a 30 wt. oil.
Its a proven fact lighter viscosity oil makes more power with less pumping loss. I would not recommend putting in 0-40 in place of the 0-30.
Check this out below.
0W-30 to 5W-40 ??
I remember that post & have never ran 40 weight since.
stevewithOCD
- Jan 1, 2008
- 900 R
2006 Apex RTX
I think, just like the Apex, 0w-30 Semi-Syn or 0w-40 Full Syn is Yamaha's recommendation
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Almost trolling time as the walleyes have finished the spawn! Wonder if my Yamaha outboard will run better with a 0/30 weight oil? Lol. Had to. SorryYep, like someone's trolling.
stevewithOCD
- Jan 1, 2008
- 900 R
2006 Apex RTX
I also remember Allen Ulmer using a dyno on an Apex found that Gibbs 0w-20 gained 3hp over the 0w-30 Semi-Syn
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
Your ultimate decision on what weight oil to use really is determined by testing and wear analysis. You want to run the lowest viscosity possible without sustaining excess engine wear. You also need to take into consideration what your bearing clearances are set too. Running a slightly heavier weight oil like a 0w-40 opposed to 0w-30 is not much of a difference.I also remember Allen Ulmer using a dyno on an Apex found that Gibbs 0w-20 gained 3hp over the 0w-30 Semi-Syn
The very small amount of horsepower gained wouldn’t really be noticed imo. The 0w-40 would protect better when at operating temperature. The 0w-40 really is a win/win situation because the Viscosity Index is higher. This means the oil viscosity stays more consistent as the temperature changes. The 0w-40 has similar startup protection and better temperature stability for increased protection when at temperature. 0w-20 is more of a mileage oil, and if you run it you had better be sure your motor is tight and has very little bearing wear, not recommended for a higher mileage motor 4 sure. Running an oil with a lower viscosity than recommend can really get you into trouble fast. On the other hand running an oil with a slightly higher viscosity really won’t harm you, but cold starts might be more difficult along with increased startup wear. Plain and simple the full synthetic has a higher viscosity index and that coupled along with higher breakdown temperatures make it the better choice of oil for any engine. Especially a turbo because of the high heat the oil will see when passing through the turbo.
Mills
- Dec 4, 2007
- Elk Mound, Wisconsin
- '21 SRX, '14 Viper RTX, '06 Apex, '99 SX 600, '74 TL433F,
Rockerdan after seeing your post I did some more digging into oil viscosity, shear load....
I am now going to switch from 0W40 euro Mobile1 to 5W30 euro Mobile1. Thanks for your info, it got me motivated to dig deeper.
