I need help identifying the sensor behind the top section of the oil cooler. This part is not referenced in the 2007 Yamaha Phazer service manual. My particular model is connected with B/L, B/Y, and B wiring which the schematic says is the throttle switch but I'm pretty sure that is not correct.
Any help is appreciated,
SENSOR, KNOCK
8GC-85780-00-00
8GC-85780-00-00
Unfortunately, not though. The knock sensor on this model is a hexagonal bolt with a tube protruding perpendicular to the face. It is located to the top left side of the oil cooler, while this sensor is directly behind the top right section of the cooler. Any other ideas?SENSOR, KNOCK
8GC-85780-00-00
OIL PRESSURE SWITCH ASSY
8FP-82504-00-00
8FP-82504-00-00
Thanks again, but its not that either. The pressure switch is located to the bottom left of the oil cooler. I did find this though. Apparently its the oil pressure 'sender,' part 9. I still don't understand why its missing from the service manual...OIL PRESSURE SWITCH ASSY
8FP-82504-00-00
- 47K
- 147K
- 32K
