Hammer Down
- Oct 7, 2016
- Loudon, NH
- Sidewinder STX-DX 2017
Apex XTX 2012
part# help! the bolt hole oblonged and the bolt missing from rear skid. Looking for part# for the bracket and bolt. Looked at the fiche but unsure. It’s the right side when sitting on the sled. Rear skid mounting bolt and bracket. Also is the bottom hole okay to use? If so how does this change the ride?
WinderFab
- Mar 1, 2009
- Woodbridge, ON
- 2020 Sidewinder Ltx GT
I would stick with the top hole.
What year and model is your sled?
Hammer Down
- Oct 7, 2016
- Loudon, NH
Apex XTX 2012
2017 STX DX 137 I think same as LTX-DX and LTX-LE 137
WinderFab
- Mar 1, 2009
- Woodbridge, ON
I’m getting #8JY-F1954-00-00 for the bracket and #8JP-RA196-00-00 for the bolt.
Hammer Down
- Oct 7, 2016
- Loudon, NH
Apex XTX 2012
Thanks looks about right. what if I just tried to change mounting to bottom hole?
WinderFab
- Mar 1, 2009
- Woodbridge, ON
I’m not sure what the effects would be on a 2017, my 2020 came with suspension on lower hole, I ended up raising it to the upper hole and it lighten the steering considerably so I would think it would add weight to the skis/steering.
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Any idea why or how this happened? That’s crazy bad.part# help! the bolt hole oblonged and the bolt missing from rear skid. Looking for part# for the bracket and bolt. Looked at the fiche but unsure. It’s the right side when sitting on the sled. Rear skid mounting bolt and bracket. Also is the bottom hole okay to use? If so how does this change the ride?
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
I repaired mine like this and no issues!
Way less work then drilling a millions rivets..lol
ty4stroke.com
If you want more info or details pm me
My rear skid mount repair!!
get her a bagger or tow behind lawn broom and you only have to rake near objects. easyest way to rake the lawn i know about without paying some one to do it.
DennyTuna
- Jan 28, 2017
- Ohio
- 25 Winder LTX LE w/EPS
18 Winder LTX LE W/EPS
97 SX Vmax 600
Travis (Barn of Parts) also has a fix for this. Take a look.
FrozenTows4
- Nov 6, 2014
- Brainerd Minnesota
- 2014 XF7000 Sold
2017 ZR6000RS
2018 ZR6000 El Tigre
- YOUTUBE
- FrozenTows1
Not double checking fasteners torque pre-season, in season, & post season.Any idea why or how this happened? That’s crazy bad.
45ftlbs
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
I Red lock tight and over torque mine everytime now.Not double checking fasteners torque pre-season, in season, & post season.
45ftlbs
Mine happened at the end of a 1800km trip. Was fine before the trip (pre inspection before trip)
Yamajon1
- Nov 6, 2016
- Oshkosh Wisconsin
- 2016 SR Viper RTX DX
Former Yamaha sleds:
2004 Venture 600 2002 SX Viper 700
1997 Vmax 600 SX 1994 Vmax 600 1989 Exciter
1986 Vmax 540 1986 Phaser 1981 SRX 440
After torquing with lock tight I mark all my suspension bolts with a black sharpie. I put a straight vertical line on the bolt head. Then you can glance over them pre ride and see if any have moved and if so re torque.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
I like that !! Thanks for your idea.After torquing with lock tight I mark all my suspension bolts with a black sharpie. I put a straight vertical line on the bolt head. Then you can glance over them pre ride and see if any have moved and if so re torque.
Yamarus
- Oct 4, 2021
- Russia
- Russia
- Yamaha Sidewinder B-TX LE 153
Sledroll
- Dec 19, 2005
- Muskoka , Ontario
- 2022 SRX LE
2017 SW LTX LE
If it was lower hole or no riding , I would try the lower hole , until a proper fix option can be done .Thanks looks about right. what if I just tried to change mounting to bottom hole?
I stuck a piece of bolt in the egged out part and tightened up and rode for the rest of the season .
Then do what I did and buy a new sled to ride and get the parts to fix the old sled , and then keep promising yourself that tomorrow you will get it fixed , unless it conflicts with riding time (which it does) , and a season has gone by and it is still not fixed , completely , but atleast I have made some progress , so the repair can be finished in the summer , UNLESS , it conflicts with my boating activities ...........
