PCV Not loading Map.
Vmax4creed
PEI
Canada
2010 APEX
My map is only downloading 50% of the map on the status bar did anyone ever see this before didn't have a problem with my pc now my brother is trying to load the map to make changes for me & it will not load on 2 different pc's but will load his no problem.
Maybe Allen can shed some light on this. @Srxspec
Is it possible that the map you're trying to load has a fuel & ignition tables in it, but you only have a Power Commander and no Ignition Module?
If so, simply load the map, when it gets to 50% and locks, hit the "Get Map" button and see if it pulls the map up.
If you have a Power Commander & Ignition Module both, do you have a USB chord plugged into both units?
I have both but am only plugged into 1 the PCV but i will try both & see if that helps the situation
You must be plugged into both. The PCV & Ignition module are "paired" together, so it must communicate with both when trying to send maps.
Bringing this back up because I’m having a similar issue. @Srxspec sent me an updated map for my ‘16 Apex and I had success loading it from my email to my PCV software, but can’t get it to load into the PCV. The “send map” icon will not respond, the font is dull like the operation it’s not available for some reason. The “save map” and “open map” icons work just fine. Any ideas guys?
Make sure you have a hood USB cable. Sounds like it’s not turning it on.
Can you pull the map form PCV
I’ve got data while the sled is running, RPM, TPS, etc, but I haven’t had success pulling the current map out, no. I’m pretty sure my cord is good, but maybe the PCV USB port is a little buggered? The PCV software says the device is connected and there’s no errors or warnings present either, so I’m kinda stumped.
Sled has to be off and then you plug in USB cable and it will power it up and then you should be able to pull the existing map and save and upload a new map.
In my situation my ignition module crapped & it was playing some havoc on my PCV.
No ignition module at play here and the computer I borrowed has been given back. All I’ve got at home is a Mac, so need to figure out a way to keep digging here until I resolve this issue.
Well it looks as though the USB port on this used PCV is F’d, gonna try and have the port replaced and try again. :o|#$%&*
Are you bringing it back to town for a repair, if so, drop it by and I can take a look.
Sled’s at home in the garage now. I’ll pull it off tomorrow if I can the chance and shoot you a text. Thanks pal!
