pcv ptî problem not powering down
Joe ltx-le
Beaverbank-ns
Canada
2017 sidewinder ltx-dx
after changing some settings on my pcv pti , the unit will not power down. the pcv pti auto tune and pod 300 all stay on even with the key removed. im sure it would drain the battery, the only way to turn them off is to unplug the main harness.
anyone experience this problem or have any insight
Had this happen on a friends sled that the gems would not power down. For some reason the ecu was stuck on. Remove negative on battery for a few min and it fixed our problem. Maybe it will help u too. Never stayed stuck on for the test of the day for and seam to cure the problem.
Thanks man. This seemed to fix my issue also. For now anyway.
I found an annomely with the isc relay. It seems to have power all the time and was buzzing with the key off. But I'm not an electrician and I can't figure that one out.
Cat junk..
