dlinebacker36w
Got a 15 Viper with pcv ignition module and AFR status light is green and grounds look good but will not start it set for a week or two outside and drug it in shop took pcv stuff off and it fires right up. Tried to take a little fuel at low rpms and tried adding some and neither helped. But when first went to start it fired up and ran for a minute low temp light went off tried to move it gave it gas and it stalled and never fired back up til I removed pcv stuff . where to start ? Got good voltage too.
Send it back. Pcv is probably faulty
dlinebacker36w
Anyway to trouble shoot and make sure I have ignition module too
Call Power Commander. Sounds like a wire is maybe loose.
dlinebacker36w
I called them they said to unhook ignition module and see what that doesCall Power Commander. Sounds like a wire is maybe loose.
I would keep working with them or contact the place you bought it from. I would bet money there is a wire loose or not connected correctly.
dlinebacker36w
I'm thinking loose wire too BC how would it just go bad sitting it ran fine for 500 miles in Michigan two weeks ago
Sent from my XT1254 using Tapatalk
Did you unplug it from the main harness and look to be sure there is no corrosion on the plugs. Also did you go thru every connections and make sure its plugged in correctly and there is no loose wires.
