KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
JT,
You got to try a different muffler on there ASAP. That muffler is killing you I believe, get a known good muffler on before doing anything. Seen this before with homemade or cheap mufflers.
Also, get some more Boostane or better fuel in there. Lights on the dash = not good. Lots of timing being pulled befor the dash lights up, dash flashing is a lot of HP being pulled!
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
Honestly, good question. I suppose we assume for the most part.I’m following all these discussions closely as one can never learn enough. One question i have is ot safe to assume that everyone posting clutch weights is running the stock sidewinder clutch and not the apex style??
I look for clues. Dalton black orange v2 6/2, Qay-70's, etc.
Those two clues let me know he's using a primary and secondary from Yamaha.
I also think for the most part guys are pretty clear. Especially when trying to help others.
Doc Harley
- Oct 17, 2016
- Here & there
I performed a boost leak test. And did not test those clamps! I'll retest this week and verify. TyDid you check your exhaust pipe coming to turbo for leaks, mine was doing the same, ran fine but not making power, I have hurricane tunes, talked to Dave and he had me put thin rubber in pipe next to turbo and reclamp then pressure test, the lower clamp by gas tank was leaking bad, took some messing around to get it to seal but I have my power back now.
Doc Harley
- Oct 17, 2016
- Here & there
Well to be honest, it wasn't that cheap. Just may need an adjustment.JT,
I wanted quite first and foremost. Going to a 2.5" versus the factory 2" I thought would help no matter what. And didn't know the risk of buying the bundles.
Click 250, click 270, click 280.
I don't remember signing a disclaimer?!?!
I think you were right the whole time....240 & an XS825.
rev them up
- Apr 3, 2006
- Prince Edward Island, Canada
- 2011 Nytro XTX, Hurricane Exhaust, K&N, Pcv, Autotune, Pod300, Star Suspension,
2018 Sidewinder, TD Max Spool 17, CAI, TD 3 Inch Stock Muffler Mod, 3Bar, BOV
My sled came with GGB mountain can..straight thru design. i was running 72ssh grams on ms17, put td stock mod muffler 3inch on running 76 grams, 18.2 boost, 9000ssh rpm. could very well be your muffler.
Doc Harley
- Oct 17, 2016
- Here & there
I didn't get to that point with certainty. I tried 280 at 9000 a few times then click to 270 and saw the same RPM and I thought I was crazy. So I clicked it again to 250 and RPMs 9000.Were the boost readouts different for each tune?
This went on for a while while I was practicing holeshots.
Everything's going to turn to mud in the next 48 hours.
Doc Harley
- Oct 17, 2016
- Here & there
I'm starting to believe it's true.My sled came with GGB mountain can..straight thru design. i was running 72ssh grams on ms17, put td stock mod muffler 3inch on running 76 grams, 18.2 boost, 9000ssh rpm. could very well be your muffler.
rev them up
- Apr 3, 2006
Are you 100% sure the tunes are being switched and not locked on a certain tune? There should be a difference between each tune, boost reading, rpm something.I didn't get to that point with certainty. I tried 280 at 9000 a few times then click to 270 and saw the same RPM and I thought I was crazy. So I clicked it again to 250 and RPMs 9000.
Doc Harley
- Oct 17, 2016
- Here & there
The only thing that's on the dash is the horsepower reading up in the left hand corner. And you toggle it with the left upper toggle switch.Are you 100% sure the tunes are being switched and not locked on a certain tune? There should be a difference between each tune, boost reading, rpm something.
I actually have to look at it to make sure it switches.
Doc Harley
- Oct 17, 2016
- Here & there
I said this to another member, "if not for the multitune bundle I would have never known there was a problem"
rev them up
- Apr 3, 2006
To bad the weather was not cooperating with you and you had someone close to borrow there muffler and 3bar,cai(if you dont have one). Only takes minutes to change and may give you an idea if one or all items are needed.I said this to another member, "if not for the multitune bundle I would have never known there was a problem"
Doc Harley
- Oct 17, 2016
- Here & there
I have gotten offers on mufflers. So that's being arranged.To bad the weather was not cooperating with you and you had someone close to borrow there muffler and 3bar,cai(if you dont have one). Only takes minutes to change and may give you an idea if one or all items are needed.
With 40's coming, could be a while for results.
Other than today, I've been testing 5hrs away. And even their conditions have been less than perfect with warm temps and horrible lake surfaces.
THEPASMAN
- Mar 25, 2019
- The Pas Manitoba
- 2017 Sidewinder LTX LE
Do you recall boost numbers with the GGBMy sled came with GGB mountain can..straight thru design. i was running 72ssh grams on ms17, put td stock mod muffler 3inch on running 76 grams, 18.2 boost, 9000ssh rpm. could very well be your muffler.
Obviously less to have to add 4 grams
How does the sound compare between the two
justinator
- Mar 25, 2007
- Maine
- 2023 Arctic Cat Riot 9000
I understand how you feel JT, nothing is more frustrating then having something not quite right and not being able to solve it right away.I could not be a guy with a snowmobile and not have miles and miles of groomed trail in my backyard, I would lose my mind in situations like this. For now I think you should focus your attention on the exhaust. Dont worry about 3 bar sensor or CAI or any of that stuff. None of it is going to make the change you are looking for. With pefi muffler on my sled all of my td tunes made proper boost levels except max 20. I ran 17.8-18.2 on max spool 17 so youd think it was making full power but it wasnt. For whatever reason hurricane 270 only made 16-16.2psi with pefi muffler and 17.5 or so with superquiet. Took me a bit to figure out as I didnt suspect muffler because ms17 made good boost. Eliminate the muffler as the issue and then continue down the list if we are all wrong.
rev them up
- Apr 3, 2006
Can't recall exact boost #details but it was a little lower. The GGB had a terrible drone. Just drove me nuts..enough to spend $600 on a muffler. The stock mod is a little louder at idle and lower speed. No drone. At crusing speed 45mph plus sounds close to stock..little deeper when you get into it. Overall I really like it.Do you recall boost numbers with the GGB
- 30K
