2008 phazer mtx 1300 miles. Phazer tops out at 60mph. Bought the sled last year with 1000 miles was completely stock besides tunnel close off kit. I added a aaen pipe before I really road it took it out a few times and was seeing. 80-85mph on the speedo. I install schmitds bros stage two mtx clutch kit, air box pods, and a power commander 5 and the sled starts topping out at 60 and doesn't wanna pull any higher. I assumed I put the secondary spring in the wrong potions so I removed both clutch sent them to schmitds bro had him do the primary overdriving and put secondary spring back to b-1. Assuming this clutching would fix the top end problem I purchased a 1.5 freeride track and some 9 tooth anti ratchet drive wheels and installed well clutches were out. Got clutches bak same thing 60 mph. Removed a little wieght from primary to get rpms at 11.5 tried secondary in a couple spots nothing. so I took the stock primary and secondary off a buddies phazer gt so it was all stock clutching and still 60. Unplugged power commander with both clutches and that seemed to have no effect. The motor sounds like its running good and I don't have any lights on.
I just don't understand how I was hitting 80-85 with just the pipe but now can't get it over 60..62. Any help or suggestions greatly appreciated
