Jason H
I have a 2007 Phazer FX that turns very hard while riding. I have adjusted the limiter strap on the suspension and installed smaller carbides in hopes that it will turn easier but nothing has seemed to work. My next thought was to possibly switch the skis but I don't want to make that investment if going to have the same issues. Looking for a few ideas.
Pattygillz
- Dec 25, 2015
- Chatham, Ontario
- 2016 SR Viper RTX DX
i found a 4" carbide on the inside and 2" on the outside worked well. I also kept the limiter strap in the stock position. Are you running with any studs ?
Jason H
Yes it does have studs. This is my wife's sled and she's a small woman.i found a 4" carbide on the inside and 2" on the outside worked well. I also kept the limiter strap in the stock position. Are you running with any studs ?
Pattygillz
- Dec 25, 2015
- Chatham, Ontario
Try running the front springs at the minimum without bottoming out.
greenenvy1
- Nov 1, 2016
- Nova Scotia
- 2016 SR viper mtx 141
2013 Apex eps (wife's current)
2007 Attak (mine last season, sold to oldest son)
1994 vmax 600 (middle son)
2005 Venture RS ( now a rental unit)
2009 Phazer RTX (wife's, sold)
Wife is running a Phazer this year as well and is complaining of the steering. I'll watch here for some suggested changes.
Hard Steering can mean Physically hard to steer or when you turn its easy but the sled doesnt go the direction you turn. What is the condition?
Jason H
Physically hard to steer.Hard Steering can mean Physically hard to steer or when you turn its easy but the sled doesnt go the direction you turn. What is the condition?
Take a look at the pivot at front with the two arms on it. Those can go tight from corrosion. Ski type and carbides also make a big difference. Is quite a few post on steering and fixes here in FAQ sticky at top:
Handling
Tie Rod End Upgrade
Loose Steering
Steering KitMore
Add Zerks to Spindles
Tippy
Inside Ski Lift
Ball Joint Fix
Ball Joint Fix more
Lowering Phazer JRE Kit
Dogbone Link and Steering Arm fixes and failures
Handling
Tie Rod End Upgrade
Loose Steering
Steering KitMore
Tippy
Inside Ski Lift
Ball Joint Fix
Ball Joint Fix more
Phazer2Viper
- Apr 14, 2014
- Slinger, WI/ Three Lakes, WI
- 2015 Viper LTX-DX 15,000 miles and counting!
2008 Phazer GT 128" track 10,444 miles (sold)
2008 Nytro RTX 136" 3800 miles (sold)
2000 Phazer 6500 Miles (Sold)
1990 Phazer II 10,000 miles (sold)
My 08 phazer did that. I found a used pair Yamaha tuners on craigslist and had 4" carbides all the way around. It fixed 90% of the hard steering i had. My dad an all bone stock 07 (except for his dooly carbides) and his steers like a dream.
ATV PRO #11
- Jan 22, 2011
- Garson, MB, CANADA
- 2014 Yamaha Phazer XTX
Loosen skid strap one hole and or raise front end ride height 1/4" at a time by tightening front springs.
