machzrobbie
Every 2011+ motor that I've taken apart running 14+ pounds of boost with stock pistons has had cracked pistons. If you're going to turn the boost up if you get 2500 miles on your motor I'd pull it apart and either put the older pistons in it, or aftermarket low compression pistons in it. The new pistons are not as strong as the older ones- never seen and older one cracked, even running 20 pounds.
tiutsi
- Dec 30, 2010
- Norway
- Norway
- Yamaha Apex XTX 2011 mcx 290
Yamaha Rx1/Attack 2007, 144 v/M10 Air, mcx 310.
Yamaha Nytro mcx/m&m 380++
Yamaha SRX 500 1982
Hi, i also have a problem with my apex 2011 mod. i have mcx 290 kit on it, i will change to piston from a 2008 apex. i am wondering if i can use rods also from 2008? they should fit in if you can use piston from older apex.
Robert.M
- Mar 20, 2017
- Overkalix
- Sweden
- Nytro XTX turbo
Considering upgrading my sled with rods and pistons with regard to this but how common is it? I mostly cruise around and sometime hit the throttle...
kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
Are you on Apex? I wouldn't run an 11 without a upgraded motor. However my trips are limited and I have to trailer so breakdowns just kill my trips. So I start out with the best 'trusted' opinions and hope for the best lolConsidering upgrading my sled with rods and pistons with regard to this but how common is it? I mostly cruise around and sometime hit the throttle...
Robert.M
- Mar 20, 2017
- Overkalix
- Sweden
- Nytro XTX turbo
Yepp, 2012 with MCX 315.Are you on Apex? I wouldn't run an 11 without a upgraded motor. However my trips are limited and I have to trailer so breakdowns just kill my trips. So I start out with the best 'trusted' opinions and hope for the best lol
kinger
- Jan 17, 2005
- Clear Lake, IA
The MCX kits seem really good but if it was me I would bite the bullet and swap them. That said if I rode from my home and wasn't worried about it breaking down and leaving me, I would maybe consider riding it until it broke then fix and upgrade everything.
Robert.M
- Mar 20, 2017
- Overkalix
- Sweden
- Nytro XTX turbo
Thanks for the input!The MCX kits seem really good but if it was me I would bite the bullet and swap them. That said if I rode from my home and wasn't worried about it breaking down and leaving me, I would maybe consider riding it until it broke then fix and upgrade everything.
kinger
- Jan 17, 2005
- Clear Lake, IA
The only worry with that would be if the breakdown scores the bore of the engine, add machining costs to re-Nikasil the cylinders and its $$$
Although I think most cracked pistons don't completely self destruct, it would have to be cracked a long time and probably some poor fuel before it would epically shatter.
- 14K
