07glide
- Aug 27, 2007
Hi guys, i am interested in one of these kits. if you dont get good fuel how does it protect itself?? Also how do i know the mapping from MC is good for my area,elevation and temp. ?? Thanks
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
You need good fuel period, 93 octane is preferable. If not you will have to run Torco octane booster or a Water/Meth-kit to avoid detonation.
MCX kits have altitude, temp and pressure compensation built in. The base maps can allways be optimized but they run great for the most part. I would not worry too much about it. The MCX computers are programmable; both fuel and boost pressure can be adjusted with the addition of the MCX Display Unit.
07glide
- Aug 27, 2007
Thanks rxrider. That is as long as MC has the map fairly close for -30C weather etc elevation 500ft. This is what im concerened about. Want this to be a reliable trail, lake sled. Thanks for the input. What does it adjust boost,timing, senses detonation??
Thanks guys.
Thanks guys.
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Norway
Adjusts boost and fuel, not detonation detection except for what's in your sled already. To my knowledge the 2011-2012 Apex's have knock detection and deto avoidance built in.
gsxr
- Feb 24, 2006
- BRACEBRIDGE , ONTARIO
- 2023 SRX
O7 , you would lov it ! Wow a great ride , don't have to tune , just bolt on and go !!
spddmon
for an 07 i would suggest the midmount kit a bit more work but quieter than rear
machzrobbie
- 36K
