bush wacker
I bought a polaris pro xr 800 track and while i was looking at it i found out every third hole is plugged. will this still work and is the driver in this sled different?
NyTrOMaNIaC
Should work fine, unless your Phazer has extrovert drivers. You could always cut out every third window if need be...
bush wacker
what would be the best way to cut it the 3rd window and if i dont will it be hard on the driver
yukonranger
If you don't have extroverts then you won't need to cut out the window, if you do have extroverts then you will need to cut out the window.
bush wacker
will it harm the teeth on the drive
yukonranger
If you don't have extroverts then you won't need to cut out the window as having the windows closed will not hurt the drivers, if you do have extroverts then you will need to cut out the window as having the window closed will hurt the driver
