Polaris track problem
bush wacker
kenora
I bought a polaris pro xr 800 track and while i was looking at it i found out every third hole is plugged. will this still work and is the driver in this sled different?
Should work fine, unless your Phazer has extrovert drivers. You could always cut out every third window if need be...
If you don't have extroverts then you won't need to cut out the window as having the windows closed will not hurt the drivers, if you do have extroverts then you will need to cut out the window as having the window closed will hurt the driver :o|
