heelingcowboy1
OK fellas--So my sled has been giving me some gremlins this year but this one made me turn back home today!! So for the last week or soo it seems that once in a while my sled would throw code 36 and bog down but never for more then a second and it was back up and running again. And this only would happen after a good 40-50 miles into the trip. So I talked to the dealer and I did the usuall stuff that goes with finding trying to find the problem; Changed plugs, cleaned the coils, and put delectric grease on them. Still having the same problem. I switched around the coils and I still get the same code 36. I checked the wiring harness and found a small spot on the ground (red) wire that was exposed but the wire was good and shiny and I took the harness up to a local garage and had it throughly tested and all was well there. So next I took off the powercommander 3 and the ignition module to see if that made any diffrence--IT DID!!! It made it worse!! It was actually running on 3 cylinders on and off yet it never threw a code!!! So the question is am I barking up the wrong tree with the electrical issue or is this fuel related??? My riding buddy mentioned my problem to a fello Apex owner and the first thing that poped out of his mind was that maybe cylinder #4 wasn't getting enough fuel at mid RPMS. The sled has 6300 miles on it--what are your thoughts???
