johan
- Jan 19, 2015
- sweden
- Sweden
- Viper Xtx mcx 270
Why I gonna install a secondary battery is that I have measure the voltage drop on the battery itself, it goes down to under 9 voltage when cranking. I see only one fix to it, supply the ecu with a secondary battery or capacitator to supply the needed voltage it requires. maybe we can try a stronger main battery. but I gonna go with a secondary small battery.
4StrokeAddict
- Apr 13, 2015
- Michigan
- 2015 SR Viper LTX SE
Just caught up with this thread. I am getting the new Yamaha flash on Thursday prior to my first trip of the season. I wasn't a big believer in the low voltage issue, but seeing how low the voltage is dropping makes me think twice. With that much voltage drop with a charged battery, it does make sense that it could be a contributing problem if the ECU isn't spec'ed accordingly. A super cap right before the start relay may be a good solution to supplement power for the starter. Super caps will be smaller and lighter making them easier to integrate. If it is only required to power the ECU, you wouldn't need a big battery or capacitor either. Just use a diode and a super cap inline with the ECU only. This would be an easy fix. If using it to supplement the starter as well, super cap is the answer integrating it in front of the start relay.
4StrokeAddict
- Apr 13, 2015
- Michigan
One more thought, are we sure that the ECU is dying due to voltage drop? A properly designed ECU SHOULD have a capacitor installed to carry it through a start sequence.
Good question. How would we test that? Guess just assumed since everything else electronic does for sure lose power during start.One more thought, are we sure that the ECU is dying due to voltage drop? A properly designed ECU SHOULD have a capacitor installed to carry it through a start sequence.
Janne339
- Oct 31, 2015
- Sweden
- Sweden
- 2021 Sidewinder LTX GT
We are no sure what realy cause the starting problems and misfires. Voltage drop is one thing that we work with.
All comments and ideas are welcome.
gvessey
- Feb 8, 2015
- 2017 Sidewinder LTX-DX
2011 Apex SE Supercharged (Sold)
I wonder if a scope on the injector pulse would show if it cuts out, I don't know if a noid light would be fast enough to see an interruption. Just an idea.
Janne339
- Oct 31, 2015
- Sweden
- Sweden
Grizztracks,
When engine is running the regulator supply every critical components ,without through ISC relay? Or?
Do you know where WHT/RED and BLK goes in? What means the "D" after BLK cable?
Mtnviper
- Aug 19, 2003
- Burlington Wa.
- fourstrokesolutionsllc.com
The Red/White wire goes to the battery fuse in the main fuse block. "D" is to chassis ground location "D", although I've never been able to find the ground/component locations in the schematics.
Janne339
- Oct 31, 2015
- Sweden
- Sweden
Thanks!
grizztracks
Tech Advisor
- Feb 24, 2005
- Scio, NY
The "D" references a ground wire splice so the black wire from the regulator is spliced to several other ground wires at splice "D". The white/red wire is tied into the battery's positive feed to the fuse block after the battery fuse. When running the regulated voltage supplies power to several relays including the ISC relay and also backfeeds power through the battery fuse to charge the battery. The stator and battery are basically paralleled power supplies.
Janne339
- Oct 31, 2015
- Sweden
- Sweden
Thanks! Great work you do!
grizztracks
Tech Advisor
- Feb 24, 2005
- Scio, NY
I broke down the power distribution further. This is some crazy wiring. From what I'm seeing if the ISC, Fuel Pump or Tail Light relay fails the engine will shut down. The only relay in the Nytro that will shut the engine down is the fuel pump relay............. and that's why we now have a solid state fuel pump relay.
Mike P
- Nov 18, 2015
- Berlin CT
- Sr Viper R-TX SE
- Berlin CT
This artical I was reading will scratch the surface;
Today we are going to discuss how and why to perform a voltage drop test. Hopefully you've taken the time to read our Automotive Circuit Testing article and are familiar with the basics when it comes to testing automotive electronics. We're about to take it a step further and explain the benefits of checking voltage drop across component connections, connectors and terminals. Believe it or not, it's possible to check a power supply circuit for voltage and show a good reading of 12 volts, but still have a faulty circuit. You could check that same line for resistance and show an acceptable reading of .2 ohms, and again still have a faulty circuit. Talk about throwing a wrench into the works! How can that be you may be asking yourself.
Well, there are a few circuit problems that can contribute to this testing concern. A chaffed line that only has a couple of strands of wire will pass a continuity test, but certainly won't be capable of carrying any real current. Poor connections, loose crimps and corrosion issues may also test out fine on a typical voltage or resistance check, but when a load is turned on and current is needed across these circuits they likely won't perform as expected. Any increase in circuit resistance, even a very small one, is going to create problems. This is where a voltage drop test is used to pinpoint the source of the concern.
Voltage drop tests are most effective with high amperage circuits, and are often used when diagnosing the starting and charging systems in automobiles. As such we will cover testing both systems in today's article. A voltage drop test is done on a "live" circuit, meaning that you must create a load in the circuit while taking your readings. Voltage will always follow the path of least resistance. A circuits wiring and connections should have next to no resistance and as such, all voltage should be used through the load. The "load" is the component using the power, such as a light, starter or blower motor. If a circuit has excessive resistance, it prevents the wire from carrying sufficient current under high load conditions.
When you place your meter "across", or in parallel with the circuit you are testing, you are providing another path for the voltage to travel. If there is excessive resistance then your meter becomes "the path of least resistance" and you will register a voltage reading. If the circuit is functioning properly all voltage will pass directly to the load and your meter will register an acceptable reading. "Acceptable" for most circuits is less than .4 volts, although .1 volts or less is preferred. Some starter circuits can allow up to .6 volts during a voltage drop test. Anything higher than these values indicates a need for repair. Repair usually includes cleaning corossion from connections, repairing faulty terminal crimps or tightening fasteners and connectors. It is also possible that the wire guage is inadequate for the size of the load. In this instance a "heavier" or thicker wire is needed.
So that covers the basic theory behind a voltage drop test. Now let's apply this knowledge to a couple of practical applications so we can get a better idea of where to place our test leads and how to approach a complete system. Let's start with a basic starting system. To test this system you'll need to check for excessive resistance throughout the circuit by measuring voltage drop at the battery, cable connections and starter. These readings will need to be taken while the engine is being cranked. Cranking time of around 5 seconds should be adequate for solid test results. Always remember to disable the engine so it will not start while doing these tests. If your vehicle has an inertia or fuel shut-off switch you can trip this. You could also disconnect the coil or ignition circuits or remove the fuel pump or computer relays. So let's get started.
Place your DVOM (Digital Volt Ohm Meter) on the 20 volt scale. First check battery voltage by placing your meter's positive lead on the battery's positive post ( the actual post, not the clamp) and the negative lead on the negative post. We need a minimum of 12 volts to continue testing. Next, leave your meter connected and take a reading while the engine is cranking. Record this voltage reading. Now connect your postive lead to the battery terminal stud on the starter and the negative lead to the starter housing. Again, crank the engine and record the voltage reading. If the voltage reading at the starter is not within 1 volt of battery voltage then we have excessive voltage drop in the starter cricuit. We will isolate the cause by testing out the individual parts of the circuit. To check for voltage drop we can turn our meter to the 2 volt scale, or leave it set on auto if your meter is so equipped. We can check total voltage drop in the starter circuit by connecting our postive meter lead to the positive battery post and the negative lead to the battery terminal stud on the starter and read the voltage while cranking the engine. Anything over .6 volts is an excessive voltage drop and can be isolated using the following steps.
First, check battery post to cable connection: positive meter lead on battery positive post, negaitve lead on battery's positive cable clamp. Crank the engine and note the reading. A good connection should have zero voltage drop. Second, check the positive cable: positve meter lead on positive battery clamp, negative lead on starter terminal connector. A good cable will show a voltage drop of .2 volts or less while cranking. Third, check the starter connection: positive meter lead on positive battery terminal on the solenoid, negative meter lead on actual starter stud. A good connection will have a voltage drop of near zero volts. Now to check the negative side of the circuit. Total drop on the ground side should be .3 volts or less and can be checked by placing positive meter lead on starter housing and negative meter lead on battery ground post. Take your reading while cranking the engine, and be sure your connection at the starter is solid and clean. If total voltage drop on this side of the circuit is excessive, complete testing at all connections in the same fashion as the positive side of the circuit. Check the following: between battery post and clamp (zero voltage drop), cable end at battery to cable end at engine. (.2 volts or less), cable end at engine to engine itself (near zero voltage drop), and finally between starter housing and engine block (.1 volts or less). And that wraps up the starter circuit checks last move onto the charging circuit tests. So let's get started!
First check the entire positive side of the charging circuit for excessive voltage drop. Hook your meter's positive lead to the alternator output stud and your negative lead to battery positive post. Run engine at 2,000 RPM with all lights, blower motor, radio etc. on and check voltage reading on meter. Leave the rear defroster off during this check as it may create a unusually high read. An acceptable reading is .5 volts or less. If you have an out of spec. voltage drop, check connections at alternator and battery as well as for an use of undersized cable. Check the negative side for the charging circuit the same as the positive with your meter's negative lead on the alternator case, or ground strap if equipped, and the positive lead on the batttery negative post. Voltage drop on this side of the circuit should be .2 volts or less. If it's not you know what to check and how to check it!
Janne339
- Oct 31, 2015
- Sweden
- Sweden
Pic of fusebox and relays. ISC relay (Idle Speed Control) blue. Maybe guys with poor idling will test and change the relay?
Mike you do understand that what we are thinking is the issue is voltage drop to ECU. Not the starter but it also is highly important due to the voltage drop at ECU to have a real good battery and all connections. Critical.This artical I was reading will scratch the surface;
