Curtis Chambers
- Nov 19, 2014
- 2015 SRViper R-tx-Le
There is no protection on the starter , is that normal for sleds. Just a question. Attach a piece of number 10 or 12 around end of lead with a marret
bbquadrider
- Jan 22, 2014
No protection on the main circuit of a starter on any vehicle....the protection is the relay...if relay jams you better be quick taking off the battery connection
via big bad phone
via big bad phone
Yup no fuse.
Can you electrical guys explain why they felt no need to ground to chassis right at the battery in addition to engine?
Curtis Chambers
- Nov 19, 2014
Yes I'd say that's why I thought that was odd
stingray719
Yup no fuse.
Starter ground to thin aluminum might flash a hole in it but that is just a guess
bbquadrider
- Jan 22, 2014
They ground it at the engine because it is the highest electrical load and the engine is often isolated from the chassis with vibration dampers
via big bad phone
via big bad phone
Perhaps that is another thing to blame for glitches in the starting and running? Also this sled the starting system is completely independent of the ECU. That is also something out of ordinary compared to past Yamahas which would not crank with kill switch off.
I know that but its not grounded to chassis at battery like every other sled and car is.They ground it at the engine because it is the highest electrical load and the engine is often isolated from the chassis with vibration dampers
via big bad phone
Curtis Chambers
- Nov 19, 2014
I kinda thought mine was but didn't pay to much attention to it . I would think it should be otherwise it will be a floating ground whitch could cause other issues and weird voltages because it has no were to drain. That's the purpose of grounding. Get rid of stray voltage .
bbquadrider
- Jan 22, 2014
Yes the starter is wired like it was added as an accessory. .which makes sense as it is not a Yamaha chassis
via big bad phone
via big bad phone
To me there has to be a reason why its common practice to ground at battery and starter direct to batt. Just pointing out differences which often are found to be a issue.
yamahaguy
Ride SAFE
- Apr 20, 2014
- 2015 Yamaha MTX LE with MPI
There is a chassis ground over by the fuse box.
stingray719
Look at the size of battery cable, now look at surface if you bolt the cable to the thin aluminum tunnel. Not enough surface to carry the load in my opinion. When we remote mounted batteries in the back of stock cars we always bolted battery leads to the frame and not any thin metal. You could bolt negative to tunnel but would need a patch of some kind to distribute the amperage
Yes but its not at the battery like everything else. It takes $ and effort to ground at battery but everyone else still does it. There has to be a reason. That is the question. Why make the effort to ground as close to battery as possible?
bbquadrider
- Jan 22, 2014
No need for a chassis ground if no circuits like lights use it.
via big bad phone
via big bad phone
