T-rav 27
- Apr 16, 2017
- Sudbury
- Srx 700 imp,1100 turbo, mcx apex
Hey guys I was out yesterday testing my sled and when I got on the throttle it was like it hit rev limiter then all the sudden it was like the belt was slipping and wasn't pulling and just reving so I pulled it apart today after reading about the top gear and the top gear felt abit loose on the shaft and has a slight wobble the sled has 900kms just wondering off this could be my issue because my clutches and belt are very clean and I know for sure it's not the belt slipping
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
R u saying that it felt like it went into neutral?
T-rav 27
- Apr 16, 2017
- Sudbury
Yes kinda like that but still can drive and goes into reverse just as soon as I give lots of gas it's like raving in neutral but can drive really slow and it's fine
DMCTurbo
- Nov 12, 2005
I'm sure this has happened to others if I remember correctly. I'll do a quick search to see if I can find some info.
Crossfire12
- Feb 13, 2017
- New York Adirondacks
- Sacandaga reservoir
It didn’t pop out of gear if your still moving ! You would hear grinding !!Check clutches,maybe spring broke, brake partially on.
