hey guys....here is a couple things ive learned today while working with the pc3 on my laptop....this was all PRIOR to my install of any item to sled.
First be sure to load the firmware onto the pc3 using the ign module software disc....this MUST be done first and is very clear in directions from DYNOJET.....then you will UPDATE settings,following along with ign module directions.
then I wanted to play around with MAPS....to do this you must install the SOFTWARE from the disc that comes with pc3 unit....alot of this i knew already from my harley...this was the main reason i bought this,cause the pc3 is what pretty much every bike uses to piggyback the stock ECU ,to ADD or SUBTRACT fuel.....while the IGN MODULE allows for advance or retard of IGN TIMING.
next thing you need to do is load the maps into pc3....or you can simply go with a ZERO MAP,which it comes with STOCK.....this is when you need to plug the ign module into the PC3(white 10 pin plug).....then plug the 9volt battery into the other FEMALE white 10 pin plug...this powers the PC3 & ign module,and readys it to accept the new map,which you create in the pc3 sofware.
this is something i found out that you need to be aware of....if you load the MAP to pc3,using battery directly into pc3,and FORGET to hook ign module to pc3,then you ONLY will load FUEL PORTION of map....and the IGN portion will not be saved,due to not having ign module connected to pc3.....so be sure to connect the two units,then battery to pigtail before loading or changing any maps...i found this out after reading the map,and ign portion was missing,then realized what was wrong.
again...if you buy from ULMER,you will have yours ALREADY SETUP from him....ofcourse I did mine the hard way as usual...lol
another note...if you want to change a map ,you can connect laptop to pc3 when its in sled at anytime...and im 99% you can start the sled,and since the pc3 lights up and is powered,you do not need to plug in 9volt battery to load new map(but i havent tried this yet)
the coolest thing is you can see the Pc3 lights moving on left side of sled at night...thru the vent....we dont need no stinking LEDS!..lol
Dan
