Primary Clutch swap
alswagg2
Michigan
My primary clutch has a groove fairly deep on the sheaves. The sled is a 2009 Nytro. I have a 2014 Viper primary with under 2,000 miles. Are the clutches interchangable? Can I simply swap my arms and springs into the Viper clutch and install? I could not find anything on the Search option. Thanks Al
Yes Al,
The clutch is the exact same. Just switch over your internals and you will be good.
