GreenMtnRx1
On my Gt I was looking at the primary clutch and the marks on it show that the belt is only coming up to a inch from the top. Would it be better to have that come closer to the top.
i agree machining is needed to make clutches come to top,however i think that is misleading alot of people..kviper said:You will not get the belt to the top unless you have the primary clutch and helix in the driven clutch machined to allow them to shift all the way out in to over drive. (aprox 1.1 to 1) Matt at the speed shop (BBY 2000 in here) can take care of that for you. If you are 1" frome the top you are not even to it's current capacity. kviper
zipclean said:I don't really don't agree with your ideas on stock hp. can't pull the primary to to the top.Every 2 stroke I have owned pulled it to the top of prim. when clutched right.If the belt will not pull to the top then you have to clutch and gear or you aren't set right! Just how mine have all been.Maybe 4 strokes are different but the pencil marks should be worn off very close to the top.
machj said:machz your wrong on the gearing therory 24/38 will spin faster then a 24/40 i know this because my 93 machz came with a 25/40 then i put a25/44 in it and controlled my spinning problem spinning your track in snow condions our good but to high of gearing is no good i think this apexs spin way to much just my therory
Ya you are loosing big top end,it should come to w/in 3/8 of an inch when properly shifted out at wfo for 1/4 of mile run at least with stock clutching,and the further you run the higher it may go until it is closed as far as it can go stock.. Now if you just cut your helix you will gain a little bit, and may be as close as 1/4 inch from top.GreenMtnRx1 said:On my Gt I was looking at the primary clutch and the marks on it show that the belt is only coming up to a inch from the top. Would it be better to have that come closer to the top.
