Mototown
- Sep 11, 2018
- Apex 40 th
You want the 14.8 mm , stock is 14.5 mm .
The bigger the roller the slower the sled eccllerates from a dead stop at full throttle. The smaller the roller the more aggressive your clutch weights act .
Jeff Rueth
- Oct 3, 2019
- Wisconsin
- Sidewinder
Why would you want bigger if it accelerates slower?You want the 14.8 mm , stock is 14.5 mm .
Big_Phil
- Feb 5, 2014
- Wasaga Beach, Ontario
- Sidewinder RTX LE
the bigger rollers are faster in most trail situations. With the small ones. The clutch hits too hard, causes a loss of traction and the clutching over shifts.
Jeff Rueth
- Oct 3, 2019
- Wisconsin
- Sidewinder
Thanksthe bigger rollers are faster in most trail situations. With the small ones. The clutch hits too hard, causes a loss of traction and the clutching over shifts.
- Nov 11, 2016
- Cedarville, MI
- Cedarville, MI
Wondering which Thunder products are the correct ones for my Sidewinder. I see there are 2 sizes 14. something and 15. something. How do I know which ones to order
Thunder Products Clutching sells the 14.8 rollers for the Sidewinder.
Jeff Rueth
- Oct 3, 2019
- Wisconsin
- Sidewinder
Thanks I will be ordering someThunder Products Clutching sells the 14.8 rollers for the Sidewinder.
SeX Viper
- Mar 22, 2017
- Minnetonka, MN
- 2002 SX Viper
2014 SR Viper RTX
Is it normal to have a lot of slop between the bolt and pin? I just replaced the rollers which were shot and they are tight on the pin but the pin is really loose on the bolt.
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
Yes, and also partially why they rattle so much!
- Nov 11, 2016
- Cedarville, MI
- Cedarville, MI
Yes, Yamaha did not put the allen screws in the spyder to keep the pin from moving. Lot of people are using o-rings or plastic discs to keep them from moving.
Mototown
- Sep 11, 2018
- Apex 40 th
That was if someone is buying the thunder rollers .the 14.8 mmWhy would you want bigger if it accelerates slower?
Most guys don’t have their stud pattern correct causing there track to spin excessively which throws the clutching out . Which is why guys find the bigger rollers work better . If you want good quality Yamaha rollers you must order the 14.5 mm durlon bushed rollers off of 2000 Srx .
- Nov 11, 2016
- Cedarville, MI
- Cedarville, MI
The acceleration is so minimal difference that you won't even notice it. Difference between the 14.5mm to 14.8mm is .3mm. Cut that roller in half and it is .15mm (which is .005 thousandths of an inch). You won't see any slower shifting pattern until you go 1.0mm larger (which is .040 thousandths of an inch).
Changing rollers in our testing from 14.8mm to our 15.8mm didn't change any ET times. But it did change a little rpm and where it shifts the secondary.
