Dont forget Cat guys have been running BigPower Turbo sleds for 7 years already. They ride them differently anticipating a belt blow up. Think thats not a factor? It is. Its one I take advantage of many times on my much slower sled. I dont lift till there is no more room. They ALL do much earlier from what I have seen unless your only running a mile or some short race that setup is much more important for. This is a big factor. ALL us Yamaha guys have never lifted ever.
Doo guys also. Or they pay for it almost everytime.
Crossfire12
- Feb 13, 2017
- New York Adirondacks
- 2010 Z1 Turbo ,2017 zr9000, F1100 turbo, 700 srx
- Sacandaga reservoir
I don’t know my cheap $89 belt lasted all last year I have ac. My old 1100 after it was lined up didn’t blow belts, used to get over 1000 miles before I changed it because it was getting thin, past spec, had TD max tune. A lot of people can’t even change a belt on a sled and they come on HCS complaining about all the problems. If your a sled head you can figure it out, but not the dealer, most don’t have a clue. It was the TCL causing most of the problems.Yes maybe the team may be a cheaper primary than those other clutches(tap and stm) but with wider belt,need to match secondary,more pricy cat belts,and still no guarantee belts will last any longer.
Fleecer
- Jun 13, 2014
- 2019 SRX
Did some testing with 16mm rollers. Couple things I noticed:
Could run 1.5 gram heavier weights than with factory 14.5 rollers. Also, sled engaged 2-300 rpm higher. Runnability was excellent but sled was not as violent when riding. Started to get a black ring at the top of the primary, looked like might have had some slippage going on at warp speeds.
Went back to 14.5 and black ring went away. Imo...I prefer the 14.5 roller, upshift more aggressive and engagement lower. Just my findings.
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
Maybe try a roller somewhere in the middle? I have the 14.5, 15.5 and 16mm rollers. I have tried the 16mm and the stock 14.5 and found about what you did. I have yet to try the 15.5's
Fleecer
- Jun 13, 2014
- 2019 SRX
Right on.....I'm thinking once these 14.5s wear out I'll try the Thundershift 14.8s as they are a third the price and tad bigger.
Beerman
- Nov 22, 2004
- Plymouth, MN
- www.loyalshepherd.com
- Sidewinder LTX-SE
- YOUTUBE
- arttyszka
I have the Thundershift 14.8mm rollers on mine, didn't even price the stocker replacements, are you saying the TPI rollers are 1/3 the $ of stock?Right on.....I'm thinking once these 14.5s wear out I'll try the Thundershift 14.8s as they are a third the price and tad bigger.
Doowithblue
- Mar 17, 2016
- Waterloo ON
- 07 Mach z x (sold)
18- RTX LE
Has anyone ever tried Oilite or super oilite bronze bushings inside of a primary roller vs fiber? Why always fiber bushings?
Beerman, I have found the stock rollers as cheap as $43 each. I bought a set of TP rollers for $79I have the Thundershift 14.8mm rollers on mine, didn't even price the stocker replacements, are you saying the TPI rollers are 1/3 the $ of stock?
STAIN
- Feb 29, 2004
- Vermont
- Vermont
The only problem maybe the leaking of the lubricant from the oilite bushing.Has anyone ever tried Oilite or super oilite bronze bushings inside of a primary roller vs fiber? Why always fiber bushings?
theewarrior
Anyone ever find a better bushing or a solution for roller bushings going as little as a 100 miles
Mototown
- Sep 11, 2018
- Apex 40 th
Duralon bushings from Yamaha,press in a lot tighter into rollers
- Nov 11, 2016
- Cedarville, MI
- Cedarville, MI
Thunder Products Clutching 14.8mm rollers are $79.95 for the set.
Also sell 15.8mm rollers for the same price of $79.95 for the set.
And to complete your Sidewinder, we have the SW secondary rollers for $45.00 for the set of 3.
theewarrior
Are these a new style? Because I’m on my third set of the original ones
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
I got 3500 miles on my TP rollers all at 270+ hp....look great still.Are these a new style? Because I’m on my third set of the original ones
Maybe some don't last as long using heavier setups? Hard to say.
Dan
- 27K
