Sportsterdanne
With the shockwave helix set at 43 degree it wont let the secondary clutch open for overdrive, the top/front of the ramps is making contact rather than the surface i machined.
Setting the helix at a steeper angle allows for more travel but 43 degrees is what i want, so i found a stock 43 degree helix that i will have to machine.
Started with polishing the surfaces.
Sportsterdanne
Sportsterdanne
Sportsterdanne
Sportsterdanne
Sportsterdanne
Sportsterdanne
Im putting together a youtube series about my build.
edge_232
- Jan 15, 2014
- Madison WI
- 2011 Nytro MTX slowly being modded
2005 IQR Trail Converted
Very nicely done!
Nikolai
Nice video! That Walker Evans reservior shock is heavy, I weighed the one from my Pro skid the other day, over 6 lbs.
Sportsterdanne
Thanks !
Compared to other coil shocks the WE is pretty light.
I have fox float front and back now so i can tune the ride height.
My sleds geometry and weight does not compare to a stock Polaris so the spring rates where way off with the stock shocks.
Btw. Video Part 2 is almost done.
Sportsterdanne
Part 2
Sportsterdanne
Part 3.
Sportsterdanne
Part 4.
Sportsterdanne
Part 5.
Sportsterdanne
Part 6.
