MUSKIE
Was out this morning doing some high speed testing with different clutch setups and my heat light comes on..I stop and see that i aim dumping antifreeze all over trail..Found that i must have throwen a stud into the rear heat exchanger..(BIG dint and a hole)..I waited there till sled cooled down and then drove the next 1/2 mile back to shop..1 hour later went to start sled to load in trailer and the sled WILL NOT run ...And red temp. light at top of gauge stays on..SO - do i have a bigger problem then just a new rear cooler ??? Think i did motor damage ?? Will the sled not allow me to start it because there is no antifreeze in it ?? - good info. needed ....Thanks.
problem or not
I really don't think that you have done any problem to your motor. These motors are set up with heat sensors and will shut down if they get to hot. I would try dumping some antifreeze in and see if it starts.
MUSKIE
Re: problem or not
..had planned on trying that tomorrow morning..i HOPE that worksj-mac said:I really don't think that you have done any problem to your motor. These motors are set up with heat sensors and will shut down if they get to hot. I would try dumping some antifreeze in and see if it starts.
bbydan
- Feb 2, 2010
The problem with the temp sender is that it is in the thermostat housing. So no coolant means no light.
zoomzoom
MUSKIE said:Was out this morning doing some high speed testing with different clutch setups and my heat light comes on..I stop and see that i aim dumping antifreeze all over trail..Found that i must have throwen a stud into the rear heat exchanger..(BIG dint and a hole)..I waited there till sled cooled down and then drove the next 1/2 mile back to shop..1 hour later went to start sled to load in trailer and the sled WILL NOT run ...And red temp. light at top of gauge stays on..SO - do i have a bigger problem then just a new rear cooler ??? Think i did motor damage ?? Will the sled not allow me to start it because there is no antifreeze in it ?? - good info. needed ....Thanks.
Whatever you do, DONT pay MSRP for your heat exchanger. PM me and I'll help you out.
