I posted this in the engine section too, but maybe someone here has a service manual and can help me.
I just need to know how to check the cam timing before I put the engine all back together. There is a chance it skipped a tooth on the cam gears. What marks do i line up and what cylinder needs to be at tdc?
I believe it's the same as the FX Nytro. Remove the plug on the magneto side and rotate #3 to TDC. Align the "I" mark in the window. the two cams have marks that need to be aligned. Look at the Nytro manual in the nytro fax sticky.
