Question for you guys
2008 Nytro RTX said:
Does it work alot better then normal stuff you'd buy at the store? Is it worth ordering it offline?
You should be able to buy it locally...I know NAPA and Carquest sells it up here in Canada.
Hmm,Ok. a napa just opened near us,Ill stop by and pick it up. Is it alot better then most things out there?
YES!! If you pull a search using Seafoam as the keyword you'll find many post's about it. I've been using it for a LOOONNNG time. The only fuel related issue I've had is with my POS Cub Cadet pushmower with a POS HONDA motor. Run it in ALL my gas engined units. Sled's, truck's, chainsaw, trimmer, etc. It cleans, stabilizes, and preserves your entire fuel system. As an example, 165,000+ on my 03 Ram hemi. NEVER changed a fuel filter or fuel pump. Treat it once a month. Still use it my Viper, 12,000+ miles. Cleaned the carbs twice in that whole time. Put a can in it at the end of each trip. Powervalves stay cleaner as well. Enough from me, just get some and follow the instructions on the can ;)!
Dave
storage
I use the fitch catalyze pellets and have never had ant problems during storage.Gas smells like new when I open the tank to start a new season.Been using the same ones since 98.Take them out when I trade sleds and put them in the new one.Use them in all my engine from the lawn mower to chainsaw.
Sea Foam...is that the stuff that will make your hand warmers run hotter?
riverrat said:
I wish it was that easy to improve handwarnmers!!HA,HA
It is...06 apex bars.
seafoam
I bought some and then was told because of the high ether content not recommended?
This is from a yamaha tech.
He told me yamaha stablizer safest and best.
