subaru2006
- Nov 1, 2008
- Minooka, IL
- 2016 Polaris SBA
On the hyfax theres a line that runs down the middle on the sides you can see. Is this the wear limit, or do I still have to measure them? This line if you dont know what iam talking about is like a line that looks like they stuck two pieces of plastic together. I think it also gets skinner at this line?
Thanks,
Subaru2006
PS Jan28 - Feb 1st going to Lake Gogebic staying at walleye lodge..
See you there.
Thanks,
Subaru2006
See you there.
FLYBYU
use a 10 mm metric wrench. if it's smaller than that replace them
SharkAttak
the Apex/Attak are famous for burning hyfax quick, if you put on a new pair, there going to burn down fast and stop at a certain point, then you'll be fine, i've had the same hyfax on for 2 season's
TBay Sledhead
- Jan 16, 2005
- Thunder Bay, Ontario.Ca
- 06 Attak
01 SXR Long Track
To answer your question that is the wear limit.
apltx08
To answer your question YES that line you see is the wear limit...the 1st 25% wears quick and slows afterwards the use of SCRATCHERS realy reduce the wear when riding on marginal and hard packed conditions.
- 15K
