kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
She bobs around 100 RPM at and roughly at 1800, is that a carb sync issue you think or something else? I also have the clutch rattle real bad to. On my Dad's vector he had a recall on the clutch noise and it is now silent was there anything for the RX1?
Also his sled is SOOO much quieter then mine, anybody else notice that, I'm assuming the extra cylinder makes more noise, but I didn't think it would make that much. Thanks!
black john
rattel
clean the carb,s well and pay spl att to the pilot jets. then balence the carb,s. the pilot jets are very small and plug with varnish from summer storage.
Len Todd
May be time to go through the clutch. I went through my '04's this year and the roller bushings were bad. On your '03, the tower sliders could be worn down a bit also. With the engine running rough, loose sliders could casue some added noise. However, my bet is on the Rx's reduction gears. On the '03 Rxes, they were fairly noisey. Yamaha did some things to tighten them up a bit in the '04s. Also, the 3 holers do not have the reduction gears. So, I would suspect that the 3 holer would be quieter.
kinger
- Jan 17, 2005
- Clear Lake, IA
Carbs are cleaned and perfect. Where is the reduction gears I keep hearing about? Behind the secondary? Thanks guys!
black john
gears
those gears are behind the primary insde the moter. if your idel is going up and down 100 rpm,s i would still say you have problems in the carbs or you realy need a carb balence. also check your coils for voltage leak,s .
kinger
- Jan 17, 2005
- Clear Lake, IA
I'm thinking about sync'ing the carbs not sure if that would help or not.
kinger
- Jan 17, 2005
- Clear Lake, IA
Fired it up today and it oscilates between 1480 rpms and 1150 or so. Sound like I need a manameter? Thanks
- 7K
