PigeonLake
I have the best Yamaha Dealer ever. McGregors in Bobcaygeon. Re the chain Tensioner bolts coming loose. Old school adjustments to re tension not the way to go. Stay with spec. Too much tension results in distortion of the hole thereby loosening the bolt. None the less, for peace of mind they are spot welding the bolt when they upgrade my top gear with the one with holes that lubricates better. With Barn of Parts protective stuff and Rocker Dan's ski solution and Yamaha's indestructible engine I m convinced I am keeping this 8 years like my Apex
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Agree....there are a few items that once fixed, sleds should go the long haul with good maintenance.
I would say these are the big ones in order of priority.
Im sure there is more but these are higher priority things...
Dan
- Tensioner wheel screws tack welded
- Top gear(seasonally check/replaced)
- Brake side axle bearing needs loctite to shaft early on(then needs a puller to remove)
- Add chain lube to TOP of sight glass(change often)
- Roller bushings in primary(checked for play every 300 miles or so)
- Coolant hose protectors(or must clean out ice before each ride) studs help to break up ice.
Dan
ApexXTX/Viper
- May 5, 2014
- 2019 SRX, 2018 Viper LTX
I had Paul tack weld my tensioner about two weeks ago. X2 as the best dealer around. Even dropped it by the house. That's service.I have the best Yamaha Dealer ever. McGregors in Bobcaygeon. Re the chain Tensioner bolts coming loose. Old school adjustments to re tension not the way to go. Stay with spec. Too much tension results in distortion of the hole thereby loosening the bolt. None the less, for peace of mind they are spot welding the bolt when they upgrade my top gear with the one with holes that lubricates better. With Barn of Parts protective stuff and Rocker Dan's ski solution and Yamaha's indestructible engine I m convinced I am keeping this 8 years like my Apex
stevewithOCD
Yamaha, Make me Come Back
- Jan 1, 2008
- Live CT Ride MAINE
- 900 R
2006 Apex RTX
- Roller bushings in primary(checked or play every 300 miles or so)
Dan
And LOCTITE!!!!!!!
Crazy Canuk
Dan
Plan to change the track straight away when i pick up my new Winder this fall (going to be a long summer). Looks like I can check most of these off the list before mile 1.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
True...Plan to change the track straight away when i pick up my new Winder this fall (going to be a long summer). Looks like I can check most of these off the list before mile 1.
I have changed out tracks on brand new sleds many many times. While its always nice to get the track you want with the sled, it also is nice to swap a track day 1 as it gives you the ability to go into the chaincase, gear swap if wanted, tack weld tensioner, loctite the bearing on brake side, seal oil tank in a better manner, and add nickel anti-seize to the muffler bolts(forgot to add to that list).
If a guy did all this when new, chances are for a couple solid high mile seasons without issues.
Dan
Big_Phil
- Feb 5, 2014
- Wasaga Beach, Ontario
- Sidewinder RTX LE
I have to disagree about the tension, I don't think its the cause of the tensioner failing. I run mine tighter than spec, and on my brothers race sled, we run the chain super tight or we have trouble with snapping them. My stock tensioner had 8500kms before I tack welded it for piece of mind. Having the chain too loose will cause more of a shock on the whole chain case. The chain will slap around, and then whenver you pin it, that slack tightens up and slams the tensioner.
Also, it seems the old 2017 gears with no oil holes are holding up better than the ones with oil holes. 11500kms on my stop 21 top gear.
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
I agree , from what I'm seeing the problem is the bushing itself. They are sloppy day one and made of crap material. Quality control on the bushing is a big contributor to these failures.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Also with stock gears and a loose chain, the chain rubs the center post bad adding another issue.
This issue is all about a poor top gear bushing and a poor tensioner design, NOT from tight chains. We all know how tight chains have been run on sled after sled since I was a kid.
Dan
Sledroll
- Dec 19, 2005
- Muskoka , Ontario
- 2022 SRX LE
2017 SW LTX LE
Wouldn't this be a good time for Yamaha Tech to interject , and explain why their instructions on tightening the chain are what they are !!!!!!!!!Also with stock gears and a loose chain, the chain rubs the center post bad adding another issue.
Dan
AND likewise on the many other posts where their input would be beneficial to all .
I imagine they don't want to get into a pissing match , which I would think could be avoided .
They are obviously smart people , and there are obvious limitations and influences that sometimes inhibit the best in class results for all scenarios , whether it is engine ,frame,shocks , suspension ,calibrations, ................
But overall they do pretty good .
eightpilot
- Mar 17, 2009
- Mosinee WI
- 2021 Thundercat
- Mosinee WI
We will see how indestructible that motor really is after i do a leak down and valve inspection this summer. I pushed that motor hard this season with big boost and a lot of knocking....lol. Its ok tho.... I have a spare 800 mile motor on the shelf
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
These are designed by CAT.....Yamaha is just going by the manual I'd assume.Wouldn't this be a good time for Yamaha Tech to interject , and explain why their instructions on tightening the chain are what they are !!!!!!!!!
Doowithblue
- Mar 17, 2016
- Waterloo ON
- 07 Mach z x (sold)
18- RTX LE
There's a yamaha tech? Who is this person you speak of?
Yamajon1
- Nov 6, 2016
- Oshkosh Wisconsin
- 2016 SR Viper RTX DX
Former Yamaha sleds:
2004 Venture 600 2002 SX Viper 700
1997 Vmax 600 SX 1994 Vmax 600 1989 Exciter
1986 Vmax 540 1986 Phaser 1981 SRX 440
Aren’t most of us Yamaha tech’s? ...... just saying.
- 29K
