1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Owners Manual states 1/8" to 1/4" spring preload on page 36.
fast n furious
- Jan 24, 2010
- Nova Scotia
- 2008 40th anniversary apex LTX GT
Can you share pictures as I don’t have a manual thanks.Owners Manual states 1/8" to 1/4" spring preload on page 36.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
Dont forget those specs are based on a sled with junk Tuner skis. that setting is so your useless skis dont push into a tree with any loose snow. Put good skis or fix the tuners and you can really lighten up the front end by turning the center shock spring tighter.View attachment 143510 Center shock spring pre load.
fast n furious
- Jan 24, 2010
- Nova Scotia
ThanksDont forget those specs are based on a sled with junk Tuner skis. that setting is so your useless skis dont push into a tree with any loose snow. Put good skis or fix the tuners and you can really lighten up the front end by turning the center shock spring tighter.
- 9K
