Sidewinder900
- Jan 16, 2022
- Manitoba
- 2018 Yamaha Sidewinder LTX, 1997 Arctic Cat Cougar 580cc
- Winnipeg
- Gosselinconsulting.com
I am curious on what you would set your rear springs set up for a 270 LB rider. Soft medium or hard?
I usually ride soft spring and have had my shocks recharged and revalved for my weight and riding style. Just curious what other opinions are?
![](/styles/TYLifeMember.gif)
![](/styles/vip.gif)
![](/styles/donate.gif)
Upstater57
- Apr 25, 2021
- New York
- 2022 Tcat EPS,
2014 ZR9000 (sold)
1978,1979,1980 SRX (sold)
Depends on your riding style. It's the old stiffer shock/softer spring or stiffer spring/softer shock. I tend to leave the shock stock and use a heavier spring on the rear of the sled.
STAIN
- Feb 29, 2004
- Vermont
- 2022 SIDEWINDER LTX GT
- Vermont
Springs give you your ride, the shocks control the springs.
Get the correct springs for your weight. Valve the shocks accordingly
DennyTuna
- Jan 28, 2017
- Ohio
- 18 Winder LTX 50th
16 SR Viper RTX (red)
02 SX Viper ER (red)
97 SX Vmax 600 (red)
X2 on what STAIN said. Suspension experts will tell you rear torsion springs don't like to be maxed out in preload.
Turboflash
- Mar 18, 2019
- Southern MN
IMO at 270 you should not be on softest. I would start on medium but depending on conditions/trail you ride. If it wants to bottom allot, you'll have to turn them up.
Sidewinder900
- Jan 16, 2022
- Manitoba
- Winnipeg
I don't really bottom out much at all. We ride 90% groomed flat trails here.
fxnytrortxkid
- Apr 19, 2007
- Rensselaer, ny
- 09 nytro rtx
Even if you’re not bottoming out doesn’t mean you have the right springs. It also takes weight off the nose of the sled and gives it improper balance. The suspension actually doesn’t work as well too because it will couple the suspension before you have even hit a bump. At 300 I have experienced this. I put the heaviest torsion spring in Hygear had for my sled. It’s on 1 now (still stiffer than stock 3) and it actually is more compliant on the small bumps than with softer spring because the whole suspension can work as designed. They stiffen up as you go through travel. Start with the proper torsion spring and center spring. Front shocks honestly don’t change much between people and weight etc. it’s more riding style that will alter them. But center and torsion is 100% wrong from factory for anyone over 200-225lbs imoI don't really bottom out much at all. We ride 90% groomed flat trails here.
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
X2It also takes weight off the nose of the sled and gives it improper balance
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
#3 hard .I am curious on what you would set your rear springs set up for a 270 LB rider. Soft medium or hard?
