kopenytro
Hey guys, I’m sure there’s something very simple I missing here but for the life of me I can’t figure out what it is. I have also search through multiple threads and can’t seem to find what I’m looking for.
I just upgraded to a 160 pound spring on the front shock of my 2015 XTX.
(suspension is still in the sled.)
I disconnected the top shock mount from the upper arm and did the spring swap without issue.
Now I can’t get the top mount holes to line up with the shock’s mount. Any suggestions, I’m off by approximately quarter inch.
Ps: this is my first time working on this suspension. Previous Nytro owner.
Thanks guys and sorry for the stupid question.
Reduce the spring pre-load and then use a screw driver or drift punch to compress the shock to align it.
kopenytro
Thanks Tom,
I have the sled up in the air and the preload completely backed off the shock. Thinking I might drop the air out of the Float 3 and see if that gives me what I need. I tried to line up one side with a punch and start the bolt from the other side but no luck. Seems like something simple I’m just overlooking but no luck so far.
kopenytro
Ok, so I just reread your post and understand how to make this work.
Thanks again.
Thanks again.
Thanks again.
Let me know how it goes.
kopenytro
Got it!
Did what you said Tom and I had it in and tightened up in 5 minutes.
Appreciate the advise.
Kope.
Kope.
Got it!
Kope.
Let me know how it works for you!!
- 14K
