tator
do you have a part # for the rear torsion springs you put in. where did you get them?
Studroes144
- Oct 30, 2013
I don't have part #'s anymore, I'd imagine cannondale still does. They are Arctic cat springs
tator
did you and cannon dale put the same ones on? i found your part numbers posted on an earlier thread,
Studroes144
- Oct 30, 2013
Yes I believe we used the same springs
We did. But the ones I bent were one step lighter yet. The problem with the cat lighter springs is the wind is too tight. That space stocker has from bigger wind gives just a little more static sag. Have been running stock spring for a year or more now. Would like the big wind and Lighter. Ordered the new rear spring for the Cat limiteds which is 135 vs our 165. They only have lefts! Go figure. By eye it looks to have the big wind. Tator wait till I figure this out before getting anything unless you are over 200lb. Spring chart is in FAQ also.Yes I believe we used the same springs
tator
im 220 dry weight!
RacinJason15
- Jan 23, 2008
- Comstock Park, MI
- 17' Yamaha Sidewinder LTX DX
- Comstock Park
Anyone ride there ltx with the coupler block out? Does it transfer more?
Studroes144
- Oct 30, 2013
3800 miles with mine out, just a bit more transfer which it needs but sled is still planted awesome in corners.
RacinJason15
- Jan 23, 2008
- Comstock Park, MI
- Comstock Park
Any pit falls from taking it out? I just had my shocks re valved and it really transfers now but I would like just a bit more! I think I'll be taking it out before my U.P trip on Wednesday!
Studroes144
- Oct 30, 2013
I have no complaints at all, it gives the sled a bit more attitude but has no negative affect on handling or cornering. My blocks will never go back on my sled!
SnoNinja
aka "Plan B"
- Feb 18, 2015
- Gaylord, Michigan
- 2015 Viper LTX-LE
2016 Vector LE For my Bride
2007 Phazer GT, 136" Stretch.
2002 SXR600 (still own)
1997 SX600 (sold)
1997 XT500 (sold)
2013 Can-Am Maverick 1000XRS
Did you pull entire shaft, or just blocks off shaft?I have no complaints at all, it gives the sled a bit more attitude but has no negative affect on handling or cornering. My blocks will never go back on my sled!
Blocks off the shaft. For off trail you would like that.Did you pull entire shaft, or just blocks off shaft?
Studroes144
- Oct 30, 2013
Yes just the blocks and keep the shaft on
SnoNinja
aka "Plan B"
- Feb 18, 2015
- Gaylord, Michigan
- 2015 Viper LTX-LE
1997 SX600 (sold)
1997 XT500 (sold)
More wheelies, I'm all in......Blocks off the shaft. For off trail you would like that.
I got the righthand one today. Its a new spring. Not on the charts. Cat Part #2704-026. Left is on backorder. This is what I was hoping for. 16.5lb vs our 18.5 stock spring AND it has the large dia coil which will help increase sag vs the old lighter spring Studroes has and I tried. Here is picdid you and cannon dale put the same ones on? i found your part numbers posted on an earlier thread,
Top is stock 18.5 Mid is the new 16,5 and bottom is the old lighter spring we tried.
The larger coil allows some slop. Thats good in my opinion. I am putting just this one on with stock spring on other side for now and waiting for Left hand to become available. The one spring should help a little but of course would like both. I am not sure if Yamaha has this same spring in there sleds. Very well could be.
- 7K
