IS ANYONE AWARE OF A RECALL RELATING TO THE RADIATOR BRACKETS ON THE APEX SLEDS ?
I HEARD THERE WAS A CONDITION WHERE THE BRACKETS SECURING D THE RADIATOR & FAN WERE BREAKING.
FX4
there is no recall regarding that problem, if the sled is still under warranty they should cover it
LJ 452
Yes, there is a problem with the radiator brackets cracking/breaking, no there is not a recall on this issue. I would think that if you had a good dealer, even if your warranty is out, they could get you the rad from Yamaha. They probably won't cover the install, but you could easily do it yourself. It wouldn't hurt to try and tak to your dealer. It likely won't be the first one they've seen.
Thanks for the feed back.
Iwas advised by a another sledder this was a problem, I did check mine earlier today and they are secure and show no evidence of a problem.
LJ 452
I believe the issue was only on the 06's. I think they made the change on the 07's and up.
whits-end
What was the change made in '07? Can the '06 be updated to prevent the brackets from cracking?
turbine man
changed both of mine they didnt crack until 4/5000 miles one was covered under warranty the other i payed 4 they should back date ok jeff
Blue Dave
- Jan 7, 2008
- Ham Lake, MN
- '17 Sidewinder LTX DX
Does anybody know for sure if this is fixed on the '07's?
apltx08
I have a '08 w/same old brackets from '06, I used TIE WRAPS as a back up incase or when they do let go for it not to slam in to the BRAKE ROTOR and cut it open and have coolant all over the place...
If I'm not mistaking I remember seeing a post on a updated 1, the brackets where 1 big peice accross the top in place of the little TABS we have on OEM'S
turbine man
you are right on the brackets, day and night difference,
Blue Dave
- Jan 7, 2008
- Ham Lake, MN
Anybody have pics of the old and new design?
AIRWOLF
Guest
I treid to add a pic but it was to BIG
apltx08
welterracer
My dealer replaced mine under the YES plan..
THANK GOD.. that sucker isnt cheap
