20winderxtx1997
- Feb 15, 2021
- Rosemount, Minnesota
- 2020 Yamaha sidewinder xtx se
I’m running the precision efi multi stage tune. I am told I need to upgrade my fuel pump charge tubes and bov, what do y’all recommend?
Turboflash
- Mar 18, 2019
- Southern MN
Fuel pumps and injectors are maxed out at about -10 F at 280HP level.
Higher volume fuel pump a good idea not just for higher volume but the return line is routed back to where pickup is and put right into basket where suction is. Helps make SURE you don't have low fuel pressure when tank is low.
Personally, I've never had an issue with the charge tubes.
BOV for tuned sleds is a must IMO.
PEFI of course sells all these.
Crossfire12
- Feb 13, 2017
- New York Adirondacks
- 2010 Z1 Turbo ,2017 zr9000, F1100 turbo, 700 srx
- Sacandaga reservoir
So if it’s cold out , and it gets lean doesn’t the motor back off timing and slow sled up? I thought there was protection.
SledFreak
- Feb 7, 2005
- Ontario. Canada
Thats the advertisement!!!
Turboflash
- Mar 18, 2019
- Southern MN
Like SledFreak says, that's what "they" all say. Theoretically, IF the knock protection works as advertised, one should be able to hold WFO anytime you want. You go first .....So if it’s cold out , and it gets lean doesn’t the motor back off timing and slow sled up? I thought there was protection.
Crossfire12
- Feb 13, 2017
I guess will have to ride slow when it’s cold outside.
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Well if it did not work I am pretty sure we would.be hearing of multiple 998's go down especially up here in northern Ontario....
It's been between- 15 and -30 *c for the past 2 weeks... and trust me all the hurricane and td boys up this way run their tune sled hard
There is no doupt detection works!
Every year we get extremely cold weather (as low as -40*c.) And ever year we riding these cold temps with no issues...
I don't understand why all of a sudden this is a issue...lol
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
If I recall.....tuners found that there was NO ACTIVE knock protection from factory. I believe it was GAP who figured it out to make the factory sensor active. And other tuners followed.
Dan
Dan
SidewinderConvert
4-Stroke Rookie
Isn't everyone using GAP for ECU tuning tools?If I recall.....tuners found that there was NO ACTIVE knock protection from factory. I believe it was GAP who figured it out to make the factory sensor active. And other tuners followed.
Dan
- 13K
