fourload
This is from Port Yamaha's online parts detail. It is #4.
Is the consensus that the red elbow is the way to go? I believe it came on the 17s?
fourload
The old one in my 17 is red. Not sure but I think the updated one is black. I just ordered a new one and will compare it to the older one in my 17. On the 18 parts detail it says the 18's already have the new one.
silverram323
- Mar 24, 2013
- Jodrell St, Cambridge, mn 55008
- beyondsynthetics.net
- 2017 Sidewinder XT-X 141
You can carefully drill out the red 90 with a 3/16" drill bit. I did mine today vs buying a new 90.
Sent from my iPhone using Tapatalk Pro
geez150
Yes new one is black and is basically straight through. Red one is necked down to a little hole. After installing mine I tried taking it back off and broke it so I just drilled out the red one no problem. I used a 5/32 just to be on the safe side, but it is plenty open now just like the black one was. Don't forget to order a new clamp as well if you are changing the fitting.
fourload
Wonder why the change?
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
X2 what's the reason to change this out?
XP123
- Dec 25, 2016
- Chautauqua NY
- Sidewinder XTX LE 137
I just ordered the updated part. I figured it's cheap so why not.
geez150
Some had too high of fuel psi I believe.X2 what's the reason to change this out?
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
I posted this 3 days ago in another thread about cutting out....I will have to go find my post to see if anyone had replied to me. It was something Tom read on FB but I had never seen this.
My new 18 came with red elbow too. Built in July tho.
So you guys say its cause fuel pressure was too HIGH? Interesting.
Just drill it out then?
Dan
Dan
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Here was my post...back on Friday.
https://ty4stroke.com/threads/winder-cuts-out.150910/#post-1401293
Dan
Dan
Tarzan
- Oct 28, 2009
- Norway
- www.youtube.com
- Norway
Yes! If you take it of and look into it you will see it narrows. Its to smal ,its not letting enough fuel from the regulator into the fuel-tank.Some had too high of fuel psi I believe.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
silverram323
- Mar 24, 2013
[emoji15] and after reading on here, they said drill out the red 90 to 3/16". I hope this gets cleared up so i know if im good or i need to order another red 90!!!
XP123
- Dec 25, 2016
- Chautauqua NY
I wouldn't drill anything. I would just replace it with the updated part.[emoji15] and after reading on here, they said drill out the red 90 to 3/16". I hope this gets cleared up so i know if im good or i need to order another red 90!!!
- 7K
