Now that the Phazer is out of warranty, what oil are you using when you do your oil changes? If the Yamaha Lube is the best I will continue to sell my sole for the good stuff. Has anybody switched brands???
soul_hammer
i use amsoil in everything i own and have for years. i love the stuff.
Jeffz
- Feb 3, 2010
- Cresco, Iowa
- 2008 Yamaha Nytro RTX 40th
2007 Phazer "RTX"
Amsoil 5w30 full synthetic.
mx1500
0-30 synthetic oil i use and no probs at all
- Nov 1, 2009
- Winnipeg, Manitoba
- 2009 Phazer RTX
Jeffz said:Amsoil 5w30 full synthetic.
Just curious on the selection of 5w30 vs the 0w30?
Custom Rx1
- Jan 16, 2007
castrol synthetic oil. 5w 30 in my 04 Rx looks like new every year. 13000km
mx1500
0w30 came out a bit milky. but it got put on its side a few times though
Jeffz
- Feb 3, 2010
- Cresco, Iowa
2007 Phazer "RTX"
yamahas said:Jeffz said:Amsoil 5w30 full synthetic.
The first number has to do with the way the oil acts when it's cold. It's a negligible difference. Even 10w30 would work fine. The second number (when oil is at operating temp) is what you need to watch for.
RIGIDONE
5w30 opti oil since day one in both my phazers
Old Thumper
Mobil-1 0W30
Ruckus
mx1500 said:0w30 came out a bit milky. but it got put on its side a few times though
I don't understand. How could that turn your oil milky?
quebecmoutainrider
m
you have a problem...the milky is from the oil mixing with water...you must check it out...I have had my sled upside down and on its side...many .many etc,times..and never saw this..had a hair crack on my foot for the boat..and the water got in and turned it milky...found the crack with an xray//I would adress this problem...unless you got snow in it when you put oil on the trail in it..mx1500 said:0w30 came out a bit milky. but it got put on its side a few times though
07fx4stroke
I use Royal purple 0w-40 with a K&N oil filter. Love Royal purple use it in everything piece of equipment I own.
