grizztracks
Tech Advisor
- Feb 24, 2005
- Scio, NY
XTC500
So, while doing some pre-season maintenance I found the cable pulled out of the tunnel mounted RA on my 2010 Vector. The cable was pulled out of the coupler that threads to the RA. Digging a little deeper, the cable was also broken close to the shock. I'm thinking I'll not bother replacing the cable. The question is, do I clean it up by removing the rubber boot from the shock that protects the cable? Or do I leave it in there? I'd be able to get in there & adjust the shock with a screwdriver if I remove the boot, but will moisture enter the shock where the boot is fastened to it if the boot is removed? What's your thoughts.
