NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
Much quickerAgree 100% I will hopefully never do it again but if I do the throttlebodys are coming off !
A boost leak test might be the first thing to do here as its possible there are other places that may be leaking, and those clamps may not be leaking at all on many sleds.
Also, imo, these would be more likely to leak as the miles pile up because heat cycles cause rubber to slowly shrink and/or harden. If you are trading every year or two, I'm not sure I'd bother.
Turboflash
- Mar 18, 2019
- Southern MN
Hey Marc, I tol ya it would be fun!! It's an ugly job!This has been one of the most unpleasant jobs I have ever done!!!!! Lol
I had all sorts of tricks...lol
I used a pick (straight and 90*) and slide the spacer on to tip and held the bolt with the 4 mm allen wrench and carefully slide spacer on the bolt.
Once i got the spacer on I would put a dab of grease at the end of a flat head screwdriver and stuck the nut to it then hoped for the best...lol
To do this over again I think I would strip er right down
Turboflash
- Mar 18, 2019
- Southern MN
If I ever have to do it again, I would also remove throttle bodies. It would make it much easier.Agree 100% I will hopefully never do it again but if I do the throttlebodys are coming off !
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
No freeken kidding eh..lolHey Marc, I tol ya it would be fun!! It's an ugly job!
SaskAttack
- Jan 4, 2006
- Corning,SK.
- 17 Sidewinder XTX-SE
- Corning, SK. Canada
What time frame are we looking at for complete job?
snowcaine
- Dec 23, 2019
- Indiana
- 20 Sidewinder
21 ZR 9000
23 SRX
Marc said it’s a 12-pack job. Hard stuff too not the watered down stuff. Plan accordingly!
yamamarc and Turboflash
Was there any sign of the clamps on your sleds either being loose or not clamping tightly?
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
12 Budweiser!!! LolWhat time frame are we looking at for complete job?
WinderFab
- Mar 1, 2009
- Woodbridge, ON
- 2020 Sidewinder Ltx GT
Marc I’m more of a wine drinker.. will a bottle be enough lol..12 Budweiser!!! Lol
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
I managed to squeeze a turn /turn and half on all the gear clamps .yamamarc and Turboflash
The one gear clamp (intake to compressor on turbo) was just sitting there I was able to turn it on hose! Was tightened at beginning of season so must have rattled loose
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
I d get 1 or 2 of those boxes of wine..lolMarc I’m more of a wine drinker.. will a bottle be enough lol..
Turboflash
- Mar 18, 2019
- Southern MN
Yeah, I was curious about that too so before I loosened any of those clamps I tried moving or wiggling the throttle bodies in those rubber boots. On both sides, the boots have ridges or steps to match steps in either throttle bodies or spigots on head so they seem to lock in pretty well (even without any clamps). Once I shortened the spacers, I could see there was definitely more clamp force as evidenced by very slight bulge in boots at all connections. You don't want to shorten the spacers so much that it crushes the boot out of round.
I shortened mine .075" (from .250 down to .175") and I think Marc shortened his .0625" (from .250 down to .1875"). Seems to be about the right amount.
I am curious if this will be a permanent fix or if they will need to be tightened again over time? It may be that the rubber the boot is made of is done compressing after a few years and then again time will tell. I started seeing leaks in the data log on my 2017 for the first time this year so just thinking I might save some hassle and just replace the boots instead of screwing with the clamps. Anybody having issues with leaks on the newer sleds or is this more of a problem for the sleds getting long in the tooth?
Turboflash
- Mar 18, 2019
- Southern MN
Don't know for sure. Maybe chat with Dave at Hurricane since he was the one who said they've seen it multiple times.
I think they can leak even when new. Especially for those of us who have more boost than stock. From what I saw, there really isn't that much compression on the boot with the stock spacers at .250" length. Maybe Yamamarc has thoughts?
- 21K
- 9K
