yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Don't know for sure. Maybe chat with Dave at Hurricane since he was the one who said they've seen it multiple times.
I think they can leak even when new. Especially for those of us who have more boost than stock. From what I saw, there really isn't that much compression on the boot with the stock spacers at .250" length. Maybe Yamamarc has thoughts?
Dave is the guy to talk to about this since he has all the data and trends collected on the issue and resolution mod for a over active knock light that some have experienced!!
hman4
- Sep 22, 2014
- 2010 Apex, 2002srx, 2000 srx
Would this job be much easier if you made new steel bushings or some magnetic stainless?
Turboflash
- Mar 18, 2019
- Southern MN
IMO, no. Shortening the bushings is easy. It's getting them out that makes you cuss.
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
I'm tackling this right now as well as installing the upgraded wastegate/controller. Yup pain in the rear end for sure.
DMCTurbo
- Nov 12, 2005
justinator
- Mar 25, 2007
- Maine
- 2023 Arctic Cat Riot 9000
If I recall correctly, you slide the brown connector back and then squeeze the gray parts as much as you can and it will release the line.How do you remove the fuel line from the rack? I can't for the life of me get it off. I've had it off before, can't recall it being this tough.
Turboflash
- Mar 18, 2019
- Southern MN
Yes, slide lock out of way, allowing you to push in on grey pad. It helps to simultaneously push the fuel line in (like you're trying to push it on). That takes some pressure off locking mechanism.
DMCTurbo
- Nov 12, 2005
Ok I figured as much but must not be pressing hard enough. Thanks.Yes, slide lock out of way, allowing you to push in on grey pad. It helps to simultaneously push the fuel line in (like you're trying to push it on). That takes some pressure off locking mechanism.
DMCTurbo
- Nov 12, 2005
So completed this job. Hardest part for me was removing the fuel line from the rail. For some reason it was a bugger to get off. Removing the throttle body is the way to go. Now to get the new wastegate installed and set up.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Everybody should being doing this mod of shortening the spacers on the clamps. I did mine last fall. Big difference if yours are leaking boost.
blevis213
- Apr 13, 2013
- hadley, new york
- 2014 apex se
2001 srx 700
2000 srx 700
2021 sidewinder srx
I would like to get this done. Any one know of a good place in ny. I asked a couple local dealers and they weren't interested. My best bet is probably ask hurrricane just was seeing if any one was closer. 4 hour ride. Thanks
- 21K
- 9K
