ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- 2015 Viper 270 hurricane,
- Wisconsin
24/41 gears, 15 wide hyvoWhat gear/chain combo are you running?
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
I wonder how much that bigger top gear contributes to reduced wear on the bushing?
I am thinking of going to that bigger top gear
Fast
- Sep 25, 2018
Any idea when this fix will be coming out?My buddy tried those severe load bushing from McMaster Carr and they took a #*$&@ as well. Word was Cat is going to have a fix this season??????
I heard on the 2020 models. I guess we will see.
twyztid
- Feb 14, 2011
- Middleville, MI
- 2025 Sidewinder LTX LE EPS
2025 Sidewinder LTX LE EPS #2
2017 Sidewinder LTX SE
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
Anybody have any new input on this?
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Anyone try this bushing?
Skf PCZ 1616 M
I seen a guy posted this other the day on a different site
Skf PCZ 1616 M
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
If your having wear issues as I did previously.
Buy a NEW chain and upper gear with holes. Run the chain at least 1 turn loose on the tensioner and overfill the chaincase 4 oz over the sight glass. I always used redline heavy shock proof.
Upper Bushing material is not the issue, I have the stock bushing in now, with over 2500 miles and zero wear, 270 horsepower.
I thought it was from running the chain too tight but others here say they have ran their chain loose and are still getting excessive wear.
The only other modification to my setup was I replaced the chain, ran it loose and it’s holding up great. Normally I would have had to replace the bushing every 1000~1500 miles.
If the pitch on a HYVO chain is wrong/stretched it will climb on the sprockets causing upper bushing wear.
Some have had wear issues since driving off the showroom floor others have not. This tells me something has not been manufactured correctly. HYVO chain is a very precise piece requiring tolerances to within a thousandth of an inch. I would not doubt some of these chains have been manufactured incorrectly. I have been working on industrial machinery for many years, seeing many “Brand New” parts that were not made correctly or didn’t work.
In fact things have gotten worse in these past few years.
theCATman
- Feb 19, 2007
- WI
- Yamaha
This is great info & practically qualifies as a sticky.
BTW ClutchMaster.... would this also apply to the Vipers? I have to presume so?
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
Yes that’s what I run, a turbo Viper.
Thanks for the kind words!
theCATman
- Feb 19, 2007
- WI
- Yamaha
10-4 .
I really want to try a Viper, but honestly, the chaincase problems are what's keeping me from pulling the trigger.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
I thought it was 4 additional ounces over 12. So 16 total, which puts it at TOP of window.
What you said is 4oz over window.....just want to clarify.
Im aiming for 16 total to top of window.
Dan
Dan
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
Dan
I go 4 oz over once it’s close to the top of the window
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
Dan
But I don’t think that’s what cured my issues, I did that previously and still had major bushing wear.
STAIN
- Feb 29, 2004
- Vermont
- Vermont
I wouldn't let that stop you.10-4 .
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
I put 16oz in today.....Its over the window.
Dan
Dan
