Rev Limiter Question
sd5500
Spencerport, N.Y.
How do you know your hitting? I was hitting 9300-9450 today. When that high, it felt like the motor was miss-firing. Where should I be with my RPMs based on my set up(see signature)?
rev limiter is at 9400...you were hitting it. You want to be at 88-8900 or that set up.
What happens when you hit it? Is what I felt the rev limiter? Any idea where I add the weight? Tips?
If feels like the engine is missing or a cylinder is cutting out. ....and purple smoke pours out of the hood vents!! :Rockon:
Contact ulmer racing about your clutching, he'll get you straightened out.
That must have been what i was experiencing this past weekend. BUT, as far as i know the clutching is stock??
Any ideas why this would happen with stock clutching? Maybe a wearing belt?
x2 8800-8950rpm is the sweet spot for this motor
A rev limiter will sounds like a racing bike when they do a burn out with the rear tire and you hear the engine cutting. brappp brapppp brapppp brappp. Basically its a safe feature on engine. Your engine could rev up to 15000 rpm lets say and the manufacturer put a rev limiter to just that limit how high the engine can rev. If 15000 is the max they put a limiter in about 9000-10000 rpm. It's a fail safe to keep the engine from a bad situation.
I disagree with this statment...mine ran best and got its BIG top end 115mph GPS at running between 9150-9350....when it ran at 8800 it was a turd...
click on my youtube signature below and watch my tack
Mine seems like that too, runs best around 9000 ish.
Guy's this also depends on your specific sled.. Even slight changes in your belt will make a difference. Track, snow conditions, temperature.. All can play a role.
My rev limiter was kicking in early this year with belt slip in the secondary.
Was ok with easy throttle but if I was hard on it limiter was coming on around 6500 to 7500 rpm. I was playing around with fresh new softer ultimax belt and turned back my secondary spring to 60° and worked good last year. Not many miles last year so I kept the same belt, it's harder now. So I cranked the secondary spring back to 70°.
Seems this motor likes to be loaded at most all times.
hmm..making me think, because nothing is different this year. Did the K&Ns last year and don't remember hitting that high on RPMs, although only rode the hill twice last year. Maybe I should hold off on adjusting until I ride one more time.
