YamBam
- Feb 23, 2012
- Michigan
- Sidewinder LTX-LE 2018
Sled is occasionally missing at WOT 9300-9400 rpm. Installed new plugs, still misses sometimes. At what rpm does the rev limiter activate? Am I possibly over-reving the motor at WOT? Any info would be appreciated. Thanks
XTX Chris
- Feb 2, 2014
- Carnarvon Ontario
- 2009 FX Nytro XTX
2015 Viper LTX DX
I'm pretty sure the rev limiter is 9350
Sent from my iPad using Tapatalk
radianguy
- Jan 1, 2007
Rev limiter is 9400 I thought
m.schuey7
- Feb 4, 2014
- Colorado Springs, CO.
- 2011 Yamaha Nytro XTX
Your definitely over revving and touching the limiter. I think you want to keep your revs 9000 rpm max for best performance
Nytros rule
- Jan 30, 2011
- Rider Nation
- 2014 Black Viper XTX
I think your tach is a bit optimistic, rev limiter should be 9150 - 9200.
At any rate you need clutch work, more weight/less spring.
YamBam
- Feb 23, 2012
- Michigan
Thanks for the good info. Sounds like I need to add a bit of weight. Is maximum torque at 8600-8800 rpm? Let it rev up to 9000 at WOT?
Nytros rule
- Jan 30, 2011
- Rider Nation
Unless you've done something, exhaust/programer, or such stock max torque is about 8400, max HP is about 8600, so about 8800 max RPM.
You should be able to find quite a few dyno tests on here.
upei93
- Apr 27, 2008
- Dalhousie, NB
- 2017 Sidewinder BTX Hurricane 270 tune
2015 Viper X-TX LE MPI turbo
Check the top of your weights for grooved spots (especially heelclicker but stock will also groove) on top...my 09 xtx eats weights...bouncing off rev limiter was usually first symptom.
YamBam
- Feb 23, 2012
- Michigan
Thanks guys. I have installed almost everything that Schmidt Bros. has available for the Nitro including exhaust. I will check for grooves. The clutch package is from Schmidt Bros. and they did my clutch work. I think the weights are custom. I have contacted Chris and hopefully he will help me out. Hey upie93, why do the weights groove on top? Sounds like it needs to rev at 8800 maximum. Thanks for all the good info.
