markt111
Is there an updated process, in doing the search I see different processes, some of them were old post and the pics are no longer available..
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
It's in your owners manual.
markt111
my manual is from 2017, I have heard ramblings of a new process due to failures....
InRBigness
- Apr 10, 2014
- winnipeg, manitoba
just make sure you clock the gear before putting the actuator on. The notch goes about 8pm and then you rotate the actuator back until the screw holes line up. this with pretension the gear and set the notch back to locked in position.
0degC
- Jun 5, 2009
- Sudbury, Ontario
- 2023 SRX, 2017 XF 9000
Make sure sled is in forward, top gears meshed. Then install gear with indent at 6 o’clock. Then turn gear just out of indent clockwise. Install actuator in gear and line up holes for screws. The mistake some make is thinking you can’t turn gear and they force actuator to line up screws.Is there an updated process, in doing the search I see different processes, some of them were old post and the pics are no longer available..
