irish_redneck
Does anyone else have this issue? Every once in a while hitting the reverse button does absolutely nothing. I have to turn off the ignition and start again and it will function.
I have seen it happen both from drive to reverse , and when in reverse trying to get to drive.
porkchop
- Aug 19, 2010
- Central NY
- Nytro Nation
They are very touchy POS really... hit the button, it lights up reverse but is like in "neutral" (does nothing)- I just rocked it side to side and clicked in.
A dealer told me it's not lining up the splines all the time.
My neighbor did a 'lil service work along with chaincase oil & tightened the chain tension up some, it goes into forward/ reverse much better now.
irish_redneck
I'm aware of that issue... Apparently that's a belt height on the secondary thing.
I'm talking light doesn't change at all.
PS. When are my a arm bushings gonna be ready? (in case you missed it in other thread
porkchop
- Aug 19, 2010
- Central NY
- Nytro Nation
Oh you just got a shity phazer then
I did miss the bushing post, where was it?
Will find out tomorrow about getting some, got your # & will text.
irish_redneck
I have the extended warranty , so think I'll try and make them change my little console unit.
whichever thread you said you got them for $27 rather than the $75 I was about to pay ulmers
mtotguy
- Jan 20, 2011
- Montague, Michigan
- 2016 Rush 800, 2014 Viper RTX, 1983 Excel 3
reverse
I have the same problem when I run my belt too tight. Try adding a shim to the converter.
irish_redneck
hi mtotguy , are you refering to the blinking light not locking in issue, or the light not changing at all.
mtotguy
- Jan 20, 2011
Reverse
The light would blink but reverse would not lock in.
irish_redneck
thought so
but yeah, my light sometimes doesn't blink at all. it happened again last night. kill ignition, restart, works.
Cubby
- Dec 14, 2009
- South of Winnipeg, Manitoba CANADA
- 2015 Ski Doo 900 ACE Renegade Adrenaline
2007 Yamaha Phazer GT
My 07 GT has done the same intermitently. I have the updated belt and secondary shim but sometimes when I press the reverse button nothing happens - no light, no buzzing. Whenever I test the reverse it always works - just never when I need it!
I hope someone has an answer.
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
Mine does it once in a while. Sometimes it's the idle that's high, sometimes it's when the fan is running. It's as if the pcm will not allow anything non-essential to run, such as hand warmers and reverse, from drawing power since the fan is such a high draw. There have been others that have had issues with the throttle position sensor causing this.
irish_redneck
so not just a simple matter of replacing the little box then, probably something I should make them look at during the spring, before my YES plan runs out
irish_redneck
doubt my fan was running much last night it was -6 deg fahrenheit
Mooseman
- Nov 3, 2009
- Greely, Ontario
- Greely, ON Canada
irish_redneck said:doubt my fan was running much last night it was -6 deg fahrenheit
Pffft~ That's BBQ weather here with a sweater
. Anyway, some things for you to look at to troubleshoot this. Also remembered this thread with the same problem:http://www.ty4stroke.com/viewtopic.php?t=112665
porkchop
- Aug 19, 2010
- Central NY
- Nytro Nation
Mooseman said:irish_redneck said:doubt my fan was running much last night it was -6 deg fahrenheit
Pffft~ That's BBQ weather here with ONLY a sweater ON.
Fixed ya'
- 17K
- 15K
