Also look at the wiring under the handlebar pad.
Turboflash
- Mar 18, 2019
- Southern MN
Also wiring going into fuse block up front. Lots of sleds have wires rubbed through or cut on sharp corners.
Mark Simon
- Jan 3, 2019
- Cascade, Ia
- 2013 Yamaha Apex XTX
Can you check for continuity on the two wires from the button(orange) , it's a momentary switch, so continuity when depressed and open when not. The sled doesn't have to be running for this test. Report your findings.
Cheers
Cheers
We are having a hard time finding a wiring diagram to check the correct wires. Any ideas? Thank youCan you check for continuity on the two wires from the button(orange) , it's a momentary switch, so continuity when depressed and open when not. The sled doesn't have to be running for this test. Report your findings.
Cheers
no1b4me
- Dec 31, 2016
- 2019 ZR9000 Ltd iACT
Sent you a PM.We are having a hard time finding a wiring diagram to check the correct wires. Any ideas? Thank you
Cheers
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
How did you confirm your relays were good? Did you try swapping the shift forward and shift reverse relays?Having issue chasing no reverse on my 2019 SRX. Fuse and relays are good as is my reverse actuator. When hitting switch no code, beeper or R comes up on my dash. Do the switches ever go bad? Any help would be great! Thanks
Mark Simon
- Jan 3, 2019
- Cascade, Ia
Fortunately we have 4 sidewinders in the family and we've been swapping parts to check.
zxtyler
- Dec 12, 2020
- Michigan
- 2020 SRX
I have a 2020 srx . At 2400 miles the switch stopped working. Dealer repair,warranty. So they do go bad.
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Definitely check thisAlso wiring going into fuse block up front. Lots of sleds have wires rubbed through or cut on sharp corners.
lift the fuse box and check for rubbed wires underneath , also add a felt between the plate and fuse box!!
Mark Simon
- Jan 3, 2019
- Cascade, Ia
A quick update, took a week to finally get my new handlebar switch in and that fixed it. Thanks again to everyone for the help! Appreciate it.
