snowhite
Okay I know it's a tiring issue but I need to know how to test why the reverse isn't coming on at all on my '15 viper. I press the button and there's nothing, when the actuator was screwy the lights used to dim indicating that there was draw but the actuator wasn't engaging. Now it has nothing stone dead so where do I start testing for poweror where is a good wiring diagram?
Yamajon1
- Nov 6, 2016
- Oshkosh Wisconsin
- 2016 SR Viper RTX DX
Former Yamaha sleds:
2004 Venture 600 2002 SX Viper 700
1997 Vmax 600 SX 1994 Vmax 600 1989 Exciter
1986 Vmax 540 1986 Phaser 1981 SRX 440
Lightly tap on the servo motor while actuating the button and see if it tries to kick in. Contacts in these things will corrode just sitting over summer. Wiggle the button while pressing it they corrode too.Also make sure the fuses are good. Become a VIP and you can access the service manuals online.
DTJ
- Mar 31, 2016
- Brainerd, MN
- 2023 Yamaha Sidewinder XTX
2017 Yamaha Sidewinder BTX
Check your wire harness on top of oil tank and chain case. My exhaust shield wore through on mine. Problem started with the reverse light intermittently turning on when in forward. I caught the worn through wire before it got any worse.
Norse
- Jan 1, 2019
- Sápmi
- Norway
- 2013 Arctic Cat M1100 HCR 162"
Boondocker turbo 250HP(sold)
2016 Yamaha SR Viper MTX LE 162"
MCXpress 270HP, lots of mods (sold)
2021 Arctic Cat M8000 Hardcore Alpha 155"
N/A (sold)
2023 Yamaha SW MTX LE 153"
M&M Racing 270HP, Elevate, lots of mods
Does the reverse indicator appear? If so, the gear inside the actuator may need to be turned/replaced.
