buddah
- Apr 14, 2003
- Wetmore, MI
- '17 Sidewinder B-TX LE
So I come in from a nice 100+ mi ride and park my sled behind the Odyssey nose in........figured I'd back it into the garage later like "normal"........so I go out 45 min. later, start her up, and reverse won't engage......chaincase doesn't click, basically nothing......acts like you never pushed the button. I tried bumping it forward a couple of times, still nothing.......button still dead........I finally had to drag it out of the way with my Suburban (no room to turn around). Ideas???? Please!!??!!
buddah
- Apr 14, 2003
- Wetmore, MI
Seriously? Damn near an hour and not a single additional view? Where's all the supposed help?
rebmo
- Mar 8, 2014
- Rural SE Wisconsin
- 2015 Yamaha RTX-DX blk
2015 Arctic Cat XF 9000 Green (Turbo)
I have a 15, but thought I read something regarding a reverse switch recall/update for some 2014 vipers. Check your VIN with your dealer. Perhaps someone on here that had it done could chime in. That sucks, hope you get it fixed.
tator
some of the actuators are taking a dump on people. i believe if you disconnect it and use a volt meeter you can see 12 volts there when the button is pushed.
tator
try these.
http://ty4stroke.com/threads/reverse-not-working.131064/
also can take the actuator out (3 screws) and see if it turns when you push the button that will be easier.
shagman
Vendor
- Feb 18, 2014
- Cedarville Michigan
- 2017 Sidewinder BTX LE
2014 SR Viper XTX SE (Sold)
Reverse actuator is most likely dead. Check your fuse. Mine quit Saturday also. Ordered a new one today. Will be here Thursday.
buddah
- Apr 14, 2003
- Wetmore, MI
Which fuse? Where? Worked fine earlier in the day and now, nada..............Reverse actuator is most likely dead. Check your fuse. Mine quit Saturday also. Ordered a new one today. Will be here Thursday.
Wish I could be more helpful, I have not seen the problem yet on mine.
shagman
Vendor
- Feb 18, 2014
That is the same way mine was. I rode 120 miles and then went to backup, it went in reverse then nothing. Had to pull actuator off to put in forward to go home. Sucked. Fuse box is up by coolant bottle. Little black box.
shagman
Vendor
- Feb 18, 2014
You have to pull the hood to get at fuses. Also sucks.
I would bet the actuator took a crap...
Most likely. That is almost always the issue when you hit the button and get nothing. Been that way since 2012! I would think Cat would improve this part. I've only gone through one. Knock on wood. Sometimes you can remove it and if it's locked up you can free it
up and it will work again, but then it will usually crap out again.
snowriderjoe
- Feb 23, 2006
- Champlin, Mn
- 2014 Yamaha Viper L-TX
I would bet your actuator is fried. Happened to mine. Worked fine when i put it away last spring. This winter it wouldn't work just like yours. 670 miles on sled at the time. Luckily it was covered under warranty.
BTW.... I just dont sit here and wait for people to post... I do have a day job!! Sorry but this really set off a nerve for me...if it was in such high demand... we have phones and you do have our numbers.
I was busy too. When put in search was 7 pages of info to read. Sorry Buddah.
I had same thing happen last year. It was actuator. My new one is much more forcefull louder faster clunk when going in or out. Hopefully will last many years.
- 10K
