GHLYAMMY
having an issue getting the sled to fully click into reverse i have tired adjusting it and it just wont click in any ideas? havnt taken it apart yet not really looking forward to it actually lol
The linkage has to be set just right or it will not work at all.
GHLYAMMY
so just gotta sit and mess with it till its just right?
4strokeluvr111
- Aug 27, 2011
- NW Wisc.
24K miles
What year is it? $10 (?) for a VIP membership will get you access to the repair manual for your sled.
This IS NOT an adjustment that should be played with IMO!
herndonp
- Nov 28, 2012
- Freedom,NH
- 2012 Yamaha Nytro XTX
Check all bolts holding the linkage and make sure they are tight. Found a loose one on wifes vector. Top adjustment is suppose to be 1.06" of thread showing with nuts loosen for adjustment. Bottom side adjustment after doing the top is suppose to be 0 mm of adjustment open (making the threaded part longer after loosening both nuts) and then back off 1/4 turn (making slightly shorter)
Pete
Pete
thrasher
- Nov 22, 2006
- Ottawa Valley, Ontario
- 06 Vector RS ER
Mine is finicky as well. I found that when reverse will not engage, I will need to turn the engine off to engage reverse. Seems any pressure on the jackshaft from the clutches will prevent the reverse gears from meshing. Not a problem unless reverse will not engage at all. There are areas on the linkages for reverse adjustment. It doesn't take much to adjust, so make small adjustments.
Jay Jager
- Aug 2, 2014
- Prescott Ontario
- 2010 Vector GT
All repair manuals?What year is it? $10 (?) for a VIP membership will get you access to the repair manual for your sled.
All repair manuals?
All of them that we have.. not all but many. $15 VIP
